Results 1 to 10 of 10
Thread: Replace GPU
  1. #1
    Alpha Geek mohityadavx's Avatar
    Nov 2010
    Gurgaon (Delhi NCR)
    Lightbulb Replace GPU
    Hi All!
    My system is having following config :-
    Intel Core2Duo E7400 @ 2.80 GHz
    2 x 2 Gb Kibgston 800 MHz RAM
    ASUS VW193D 19" monitor
    Intel DG31PR motherboard
    Nvidia 8400GS 512 MB Graphics Card
    OS:- Windows 7 Ultimate
    I want to replace my GPU my max budget is 5K can stretch by 0.5k only if there is a really good option. Please suggest Nvidia Graphics Card only as I convert tonnes of movies for my music player (Philips GoGear SA52XX:flu-glasses2 using Xilisoft Video Converter Ultimate & love harnessing the power of CUDA. I wanna buy it within next 2-3 days so give me as many options as possible.
    PS:- I love using smileys in my posts.
  2. #2
    . Jaskanwar Singh's Avatar
    Feb 2010
    Amritsar
    Default Re: Replace GPU
    Dont be sad ur system is good!
    Anyways that software can use both amd stream and nvidia cuda! And nothing beats amd hd5670 in that range in gaming. So get 5670.
  3. #3
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Go with Jaskanwar's suggestion. HD 5670 is the best buy within 5K. It also consumes very less power, even being such a powerful card (almost equal to nVidia 9800 GT). It does not need any external power connector.
    However which SMPS u r suing?
    AMD FX 8350 @ 4.5 GHz|16 GB RipjawX 1873 MHz CL10 @ 1.6V|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus with CM 10.1 JB 4.1|HCL Me Y2 Tab (rooted)] XOLO Q800 with Ultimate V2 JB 4.2.1| Galaxy Tab 2 P3100
  4. #4
    I am the night...I am... vickybat's Avatar
    Aug 2009
    Gotham City
    Yes, my vote also goes to 5670 @ 4.5k. Terrific card for the price and doesn't require additional power connectors.
    Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
  5. #5
    Wise Old Owl Cool Buddy's Avatar
    Mar 2006
    Milky way
    HD5670 is unmatched in it's price range. However if you have trouble raising your budget you can also consider HD5570 although i wouldn't suggest that.
    To use these cards you must have a good power supply i.e. SMPS (read corsair, FSP, Antec, Tagan and not iBall zebronics, cooler master) inside your cabinet. If you don't have one already, one of the cheaper options you can consider is FSP Saga II 400W around 2k. Other good option is Corsair 400CX around 2.4-2.5k
    Nokia 5800 :(
    Canon IXUS 115 HS :)
  6. #6
    Feb 2010
    Amritsar
    yup mention the smps also as cool buddy mentioned..
  7. #7
    Wise Cold Ghoul Piyush's Avatar
    Feb 2010
    GZB.
    @mohityadavx
    but can u post ur PSU details?
  8. #8
    d3p
    d3p is offline
    PowerHouse d3p's Avatar
    Jan 2010
    Bangalore
    If used graphics card is not a issue, then my 5770 1GB can hold good.
    http://www.thinkdigit.com/forum/baza...1-gb-sale.html
  9. #9
    Nov 2010
    Gurgaon (Delhi NCR)
    sorry for not mentioning smps its intex 450watt
  10. #10
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    Locking this thread.
    Continue here: Need New GPU For old system
    AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn) | 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
    Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
    Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
    Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
    Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
  1. Replace ALL
    By mohityadavx in forum Software Q&A
    Last Post: 29-03-2011, 01:30 PM
  2. Please Help me To Replace HSF for AM3 socket
    By suyash_123 in forum Hardware Q&A
    Last Post: 19-12-2010, 08:16 PM
  3. Replace Explorer.exe in 7
    By bajaj151 in forum Software Q&A
    Last Post: 23-10-2009, 12:29 PM
  4. part replace
    By amit dutt in forum QnA (read only)
    Last Post: 26-08-2009, 11:24 PM
  5. Should i replace the new cpu fan?
    By New in forum CPU / Motherboards
    Last Post: 03-01-2008, 07:58 AM
