Results 1 to 28 of 28
Thread: cabinet suggestions...
21-01-2011, 02:59 PM #1
my friend wants to puchase cabinet , so i m posting on his behalf..
he is looking for a cabinet with 2k budget, so kindly suggest some
also he seemed to have checked some local shops and the shopkeeper showed him some Antec Nsk series cabinets which come with PSU...
are those PSU's reliable if compared to CX400, which i own..No matter how much time u spent climbing up, u may still fall in an instant. -Max Payne 2
21-01-2011, 03:47 PM #2
Re: cabinet suggestions...
those psu's are not reliable.and for the cabinet go for nzxt gamma.
AMD Phenom II X4 955BE,Asus M4A88TD-V EVO/USB3,G.Skill 4GB 4GBNQ,WD Green 500GB,CM Elite 335,CM Elite 400W,Samsung B2030.
21-01-2011, 04:14 PM #3
Nzxt gamma is a very good option. If unavailable, check out cm 430. Stay away from bundled psu's.
Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
21-01-2011, 06:49 PM #4
thanks
21-01-2011, 08:32 PM #5Wise Old Owl
- Join Date
- Sep 2010
- Posts
- 1,293
Also check out CM Elite 310, Zebronics Reaper.Though Reaper might just overshoot your budget by 0.2-0.3k.
AMD Athlon II X4 635 || Biostar MCP6P3 || 2GB Zion & 2GB Corsair DDR3 1333MHz || Seagate 1TB + Seagate 500GB || XFX HD4650 || FSP Saga II 500W || Zebronics Fantasy || LG W2043T
21-01-2011, 10:39 PM #6
just remember this
u can go for some cheap cabinet but not a cheap PSU
21-01-2011, 10:42 PM #7Broken In
- Join Date
- Jan 2005
- Posts
- 132
21-01-2011, 10:54 PM #8
Some instances do not mean that the problem/risk doesn't exists. I have seen my PC go in smoke due to a bad PSU.
And a costly cabinet will keep dust out, Temp low and Friends drooling.
21-01-2011, 11:02 PM #9Broken In
- Join Date
- Jan 2005
- Posts
- 132
If you do stuffs like over clocking etc with an ordinary cabinet and PSU , then you are at risk.
In that case you need good cabinet and PSU's which are having better cooling.
But how many of them actually overclock ?
21-01-2011, 11:06 PM #10
Thats right ishu. Well said. One should not compromise on psu at all cost. A good 80+ psu will also conserve power resulting in low electricity bills. Stay away from sub 0.5k - 1k psu's. They provide way less power than they quote.
22-01-2011, 01:39 AM #11
@scavanger007, Antec NSK cabinets are good & can go for it but just beware about the PSU shipping with the cabinet. the shopkeeper may change it for a cheap one saying that came with the cabby & thus reducing the price & making it look like a nice offer. so if buying Antec, buy Antec only & not a deadly combo.
i think i mentioned this in some other thread. someone run a power hungry card on a iBall 400W PSU doesn't mean everyone should use iBall. cause tragedy happens only once & that may end the life of your PC as a whole.
when i joined the forum 1yr ago i too had the same question. why suggest some 3-4k PSU for a mid gaming rig when 1k or less costly PSU (with higher wattage) flooding the market. obviously cause they are of bad quality.
a simple question for you: can you run a GTX460 on a local 400W PSU? but you can on a 2k FSP power supply. no need of OC. even at stock, a GTX460 will kill any local cheap PSU.
a bad mindset. OC doesn't increase power requirements lot. maybe 20-25W for the GPU & 20W for the processor. Corsair CX400W can provide around 450W or more while FSP/Gigabyte can provide their rated power without any problem. so OC doesn't matter lot for the local batch cause the true enthusiast will never compromise on PSU & cabinets, may go for a slower proccy + GPU.
yes, i was going to say that. a cheap PSU will only bring home high electricity bills that will suppress the price of a good quality PSU in a yr or two.
22-01-2011, 11:42 AM #12Athlon II X2 260 | Gigabyte GA-78LMT-S2P | HIS IceQ Radeon HD5670 1GB GDDR5 | Corsair Value 1x4GB 1333MHz | Cooler Master Elite 311 | Corsair CX430V2 | WD Caviar Blue 160GB | Viewsonic VA503m | Logitech Z110 | Sony DVD-RW AD-7240S | Generic Keyboard & Mouse | Zebronics 700VA
SteamID
22-01-2011, 11:54 AM #13Broken In
- Join Date
- Jan 2011
- Posts
- 108
Should be around 2k
22-01-2011, 11:58 AM #14Athlon II X2 260 | Gigabyte GA-78LMT-S2P | HIS IceQ Radeon HD5670 1GB GDDR5 | Corsair Value 1x4GB 1333MHz | Cooler Master Elite 311 | Corsair CX430V2 | WD Caviar Blue 160GB | Viewsonic VA503m | Logitech Z110 | Sony DVD-RW AD-7240S | Generic Keyboard & Mouse | Zebronics 700VA
SteamID
22-01-2011, 12:10 PM #15Wise Old Owl
- Join Date
- Sep 2010
- Posts
- 1,293
Ask Cilus.He might know.
22-01-2011, 12:13 PM #16Athlon II X2 260 | Gigabyte GA-78LMT-S2P | HIS IceQ Radeon HD5670 1GB GDDR5 | Corsair Value 1x4GB 1333MHz | Cooler Master Elite 311 | Corsair CX430V2 | WD Caviar Blue 160GB | Viewsonic VA503m | Logitech Z110 | Sony DVD-RW AD-7240S | Generic Keyboard & Mouse | Zebronics 700VA
SteamID
22-01-2011, 02:20 PM #17
22-01-2011, 09:59 PM #18
online will be available
22-01-2011, 10:38 PM #19
i wud suggest u to better go for cooler master elite- 2.1k.
its looks is as simple as its styleCore i7 930 ,msi x58-pro, 2x2gb ddr3 corsair xms, msi gtx 570,corsair hx 620, Wd 1tb blue , cm 690 , samsung 2233 ,apc 800va , altec lansing vs2621, hp probook core i5 450+4gb ram+320gbhdd
23-01-2011, 12:21 AM #20Broken In
- Join Date
- Jan 2005
- Posts
- 132
^ Totally agree with you.
23-01-2011, 02:30 AM #21Broken In
- Join Date
- Jan 2011
- Posts
- 108
23-01-2011, 10:26 AM #22
@piyush
in my opinion if u have a authorised dealer of cooler master in ur area then its better if u get it frm dere otherwise u can contact thunder.dragon a existing forum member so that he can transport the cabinet to u wid a lineant budget frm kolkata. i think that coolermaster will surely be available in kolkata.Core i7 930 ,msi x58-pro, 2x2gb ddr3 corsair xms, msi gtx 570,corsair hx 620, Wd 1tb blue , cm 690 , samsung 2233 ,apc 800va , altec lansing vs2621, hp probook core i5 450+4gb ram+320gbhdd
23-01-2011, 12:59 PM #23
Cooler Master cabinets are usually avl all over India. specially Elite series. so a little search locally should do the job.
23-01-2011, 09:27 PM #24
@all
i was talkin about NZXT gamma
and yea online shipping costs more
so its better to look for elite series by CM as its commonly available
23-01-2011, 10:45 PM #25
majority hates NZXT Gamma. specially the speedbreaker design.
04-04-2011, 06:37 PM #26Right Off the Assembly Line
- Join Date
- Apr 2011
- Posts
- 3
04-04-2011, 11:23 PM #27
how ? I understand why a power intensive gpu needs a good PSU, but how does having an expensive cabi helps ?Same applies for a cabinet also.Discountghar.in - Several Discounts from flipkart.com in one place
Search Indian tech bazaar forums. Its back online!
Computer parts search Engine(for india) : http://goo.gl/Sg8Yv
04-04-2011, 11:43 PM #28
What do you mean by expensive Cabinets ???
an el-cheapo cabinet doesn't have proper expansion bays, ventilation for proper air flow, adequate fans & accessories. The most important factor is Cable Management & headroom inside your cabinet.
No space for SLI or CF cards & build quality is manageable.
For some fellows, looks is very important even.
Whereas in case of quality cabinets, you get three different kinds of cabinets
1. HTPC or Mini ITX.
2. Mini Towers
3. Mid Towers.
4. Full Towers.
Quality cases have all the accessories like screws, nuts, Cable ties, Floppy expansion bays, USB 3.0 expansions & much more included in the price.
Hassle free assembling & DIY for enthusiast for better coolings. Space for Water coolings & air coolers too.
Build quality is far better than cheapo's.
A premium cabinet can be obtained by paying just 2k -3k [NZXT Gamma or CM RC430 Black ] - Starter Range..& ranges goes upto user's wish...
Now a cheap cabinet can be purchased by paying 1.5k & if you add another 0.5 you get an edge.2600k|Maximus IV Ex-Z|Venomous X RT CM R4's Push Pull|RipjawX 16GB|Sapphire HD7970 CF [1250MHz]|OCZ Vertex 3 120GB|WD Black Raid 0|AX850w|Asus Xonar DX|Dell U2412M x 3 Eyefinity|HAF 932 Advanced|Sentry II| Logitech G27, G15, Attack II, C310 HD|Razer DeathAdder, Megalodon|Steelseries Ikari Optical|
My Game Collection & Sapphire HD 7970 Unboxing
Suggestions for a new CABINET for my pc....
By anubhavrawat in forum Power supply / Cabinets / ModsReplies: 4Last Post: 24-07-2012, 01:31 PM -
how is this Cabinet? need suggestions
By RON28 in forum Power supply / Cabinets / ModsReplies: 9Last Post: 10-06-2012, 03:41 PM -
need help on cabinet and suggestions on rig
By ROXTAR in forum PC Components / ConfigurationsReplies: 8Last Post: 20-09-2011, 08:54 PM -
PC Cabinet Suggestions
By pranavrules2007 in forum QnA (read only)Replies: 1Last Post: 31-10-2007, 12:57 PM -
Motherboard and Cabinet Buy-Suggestions Please
By karthik_rcs in forum CPU / MotherboardsReplies: 5Last Post: 31-10-2006, 07:01 AM
LinkBack URL
About LinkBacks
