Results 1 to 27 of 27
09-11-2010, 11:30 AM #1Right Off the Assembly Line
- Join Date
- Nov 2010
- Location
- Bangalore
- Posts
- 15
PC for animation and home use under 30K
Hi all,
Please suggest the best config for learning animation (like, photoshop and other high end software's) and for home use. My budget is upto 30K.
Thanks in advance.
09-11-2010, 11:43 AM #2
Re: PC for animation and home use under 30K
AMD Phenom II x6 1055t @ 9.5k
Gigabyte GA-880GM-UD2H @ 4.5k
G.skill 4GB DDR3 1333 Ripjaws kit @ 4.2k
WD 500GB Blue @ 1.8k
FSP saga II 500W @ 2.1k
CM Elite 310 @ 1.5k
Benq G2220HD 22" @ 7.5k
Total - 31.1kUPlay - Jas808, Steam ID - HD6950, TF2 Outpost - Link
Athlon II x4 635, CM Hyper 212 Evo, Gigabyte GA-880GM-UD2H, G.SKILL 6GB, Sapphire HD6950 1GB (Unlocked - HD6970), WDC 500GB Green, Corsair GS600, CM Elite 430, DELL ST2220L, X360 Controller, Logitech G400, Razor Goliathus Omega - Speed
HP Pavilion G6 2005AX - Genuine Windows 8 Pro, Samsung Galaxy Y Duos
09-11-2010, 12:37 PM #3Wise Old Owl
- Join Date
- Sep 2010
- Posts
- 1,293
Awesome Jas!!X6 within 30k!!
But won't he need a GPU for those softwares?
09-11-2010, 02:15 PM #4
^^ door open for GPU upgrade when OP wants. at least better than a system that lasts only 2yrs under load of the newer & power hungry animation softwares.
10-11-2010, 06:59 PM #5Right Off the Assembly Line
- Join Date
- Nov 2010
- Location
- Bangalore
- Posts
- 15
@ Jaskanwar r these prices also applicable in Bangalore? r these same?
10-11-2010, 09:50 PM #6
the prices all over india may vary by 100-200 bucks. they may be cheaper or costly..
11-11-2010, 10:35 AM #7Right Off the Assembly Line
- Join Date
- Nov 2010
- Location
- Bangalore
- Posts
- 15
11-11-2010, 10:46 AM #8
GPU is "graphics processing unit" popularly known as "graphics card"
11-11-2010, 02:48 PM #9Wise Old Owl
- Join Date
- Sep 2010
- Posts
- 1,293
n CPU stands for Central Processin Unit!
GPU comes into play when graphics processin is needed like games,video editin..It lessens the load on CPU so tht CPU is free for CPU intensive tasks!!
11-11-2010, 05:35 PM #10
Rocky- can you list everything you need to buy? speakers? UPS? k/b? ...
I am a bit unsure if someone needs X6 for learning animation and home use.
Maybe a X4 945 is VFM enough (or even a X4 635 maybe) and diverting a bit towards getting a good PSU for future GPU upgrade and long term reliability.
X4 945 - 6.6K approx
ASUS M4A88T-M - 4.8K approx ASUSTeK Computer Inc.
2x 2GB DDR3 1333MHz - Corsair 4K approx (/ Kingston 3.4K approx)
500GB Seagate 7200.12 - 1.7K approx
Corsair CX400 PSU- 2.7K approx (/ VX450 - 3.5K approx)
CM Elite 310 cabinet- 1.6K approx
22" 1080p LCD - 7.5K-8K approx
Total- Approx 28K-30K
To get a rough idea on prices- http://www.deltapage.com/list/index.html
11-11-2010, 08:08 PM #11Right Off the Assembly Line
- Join Date
- Nov 2010
- Location
- Bangalore
- Posts
- 15
@ pegasus....Yes...i'll need a decent 2.1 ch speaker...and UPS maybe APC....and a set of USB keyboard/mouse. I guess i'll ve to extend my budget to 35K?
Also is X4 945 is AMD???
Let me know of more configs....thanks
Jasy and ssb1551....thanks!!Last edited by Rock; 11-11-2010 at 08:09 PM. Reason: Automerged Doublepost
11-11-2010, 08:14 PM #12
AMD Phenom II X6 1055t @ 9.5k
G.skill 2*2GB DDR3 1333MHz Ripjaws @ 4k
WD Caviar 500GB Blue @ 1.8k
Corsair VX450W @ 3.5k
CM Elite 310 @ 1.5k OR NZXT Gamma @ 2k
Keyboard & mouse @ 1k
Altec Lansing VS 2621 @ 1.5k
TOTAL 34.8K
YesAlso is X4 945 is AMD???Last edited by Ishu Gupta; 11-11-2010 at 08:21 PM.
12-11-2010, 11:13 AM #13Right Off the Assembly Line
- Join Date
- Nov 2010
- Location
- Bangalore
- Posts
- 15
Thanks Ishu...
I believe the price of UPS/Power Supply Corsair VX450W @ 3.5k is a bit on the higher side...suggest me a good UPS which is maybe around 2K?
12-11-2010, 11:22 AM #14Wise Old Owl
- Join Date
- Sep 2010
- Posts
- 1,293
^^didn't get u.."higher side"!Everywhere u'll find the PSU for arnd 3.5k give or take a couple of hundred bucks.Usually higher side means the price quoted to 1 by the retailer is more than the others,is it the case wid u?Or is it somethin else?
Oh n UPS n Power Supply r 2 different things not d same!If u want UPS for arnd 2k u mite look into APC 550VA(hope I got the model no. rite).
12-11-2010, 11:55 AM #15
Go with the config that Jas suggested. FSP saga II should do given your requirement. Photoshop is a CPU driven applications and hence, it's better to have better CPU than GPU. GPU kicks in if you do 3D modeling or video rendering. The combination of X6 and 880G should be good enough.
If, in the future you gain more knowledge on PCs etc and plan to buy a GPU in the future, you better get a VX450W atleast.Samsung Galaxy S3 running cm10.1 nightly, Samsung Omnia W, Thinkpad T430 (Core i5, 8GB RAM, 160GB SSD, 14" 1600x900,9cell battery). Desktop: AMD Athlon X2 7750 BE, 4GB DDR2, 1TB HDD, 2600XT, 19" LCD
12-11-2010, 09:56 PM #16
As he is learning those softwares, I think that a mid-range GPU would be good enough. Here's my suggestion -
AMD athlon ii x4 635 @ 5k
Gigabyte 880GM UD2H @ 4.5k
2GB DDR3 1333MHz G.Skill Ripjaws @ 2.1k
CM Elite 310 @ 1.5k
Sapphire/MSI HD 5670 512MB @ 5k
BenQ G2220HD @ 7.5k / Dell ST2220 22" LED monitor @ 8.5k
Logitech K+M combo @ 0.7k
APC 550VA @ 1.5k
Total: 31.7k / 32.7k
15-11-2010, 11:21 AM #17Right Off the Assembly Line
- Join Date
- Nov 2010
- Location
- Bangalore
- Posts
- 15
@ ssb1551 Oh...i didn't knew that UPS and Power supply are two different things!!
@ desiibond...now I understand that CPU consists of:
CM Elite 310 @ 1.5k
APC 550VA @ 1.5k UPS
And GPU consists of:
FSP saga II 500W @ 2.1k Power Supply
Is my understanding correct? Please help me in clarifying this.....
thanks in advance.....
@ Cybertonic Thanks....Last edited by Rock; 15-11-2010 at 11:30 AM. Reason: Automerged Doublepost
15-11-2010, 11:48 AM #18
NO
The Big CPU / Dabba that consists the graphic card and Power supply too. And it does not consist. the UPS.
15-11-2010, 11:57 AM #19Wise Old Owl
- Join Date
- Sep 2010
- Posts
- 1,293
GPU doesn't consist of Power Supply n card(in ur case 5670).HD5670 is d GPU itself.It is made up of millions of transistors n other stuffs.
Power Supply,as d name suggests,powers ur rig.
15-11-2010, 12:48 PM #20
Don't confuse him further by going technical (transistors etc).
@Rokcy, Just go and get the config given by Jaskanwar and worry about the GPU/CPU later. Ask the dealer to assemble it for you. And all that goes into that cabinet will be part of CPU and a GPU is this:
http://benchmarkreviews.com/images/r...0_Front_01.jpg
It sits inside the cabinet (http://www.pcdistrict.com/modules/pr...c-4187.jpg)and is part of CPU.
Once you get the system, open a thread asking whatever you want to know.Last edited by desiibond; 15-11-2010 at 12:56 PM.
15-11-2010, 01:24 PM #21Wise Old Owl
- Join Date
- Sep 2010
- Posts
- 1,293
10-05-2011, 11:05 AM #22Right Off the Assembly Line
- Join Date
- Nov 2010
- Location
- Bangalore
- Posts
- 15
Hi All,
Sorry for being away for a long time. Actually due to some financial probs...i just delayed purchasin d PC. 2day I went to SP road and found the prices:
AMD Phenom II X6 1055t @ 7950
Corsair 4GB DDR3 @ 2100
WD Caviar 500GB Blue @ 1950
CM Elite 310 @ 1.5k
Benq G2220HD 22" @ 7400
Yes, they or no other shops in SP road have Gigabyte GA-880GM-UD2H, FSP SAGA II or Corsair VX450....they do not have these items....please tell me what to do?
Also, is APC 600 VA enough for these config? coz that shop guy says that its equivalent to Numeric 800VA?
Guys please help me...
11-05-2011, 02:46 PM #23
sandybridge is there for you now.
APC 600 will suffice. though for future upgrades for graphic card etc get apc 800va.UPlay - Jas808, Steam ID - HD6950, TF2 Outpost - Link
11-05-2011, 07:56 PM #24Right Off the Assembly Line
- Join Date
- Nov 2010
- Location
- Bangalore
- Posts
- 15
Hi Jassy,
Thanks. But I like AMD based system, however, I'll check if the above config is available.Last edited by Rock; 11-05-2011 at 08:07 PM.
12-05-2011, 09:57 AM #25
As suggested by Jassy..
If you have any GPU upgrade in your mind, then get a Seasonic S12II 520w for cards like 6850 or 5870 or higher like CM Silent Pro M600w.....
Otherwise FSP saga II 500w can handle 5670, 5770 wihtout any problems.
All the prices mentioned here are excluding taxes..Last edited by d3p; 12-05-2011 at 10:02 AM.
2600k|Maximus IV Ex-Z|Venomous X RT CM R4's Push Pull|RipjawX 16GB|Sapphire HD7970 CF [1250MHz]|OCZ Vertex 3 120GB|WD Black Raid 0|AX850w|Asus Xonar DX|Dell U2412M x 3 Eyefinity|HAF 932 Advanced|Sentry II| Logitech G27, G15, Attack II, C310 HD|Razer DeathAdder, Megalodon|Steelseries Ikari Optical|
My Game Collection & Sapphire HD 7970 Unboxing
12-05-2011, 11:23 AM #26
AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
| 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
12-05-2011, 07:03 PM #27Right Off the Assembly Line
- Join Date
- Nov 2010
- Location
- Bangalore
- Posts
- 15
Thanks.....I'll check the availability of Intel based config.....if its available I'll go for it
Animation PC for 30K
By pincy in forum PC Components / ConfigurationsReplies: 7Last Post: 01-05-2011, 12:52 AM -
Connecting Vista Home with XP home
By navisangha in forum Software Q&AReplies: 3Last Post: 09-11-2009, 01:32 PM -
Animation
By ankurhotnot in forum Career Planning and ProgressionReplies: 2Last Post: 20-04-2009, 07:20 PM -
Govt job at home or company job away from home?
By pimpom in forum Chit-ChatReplies: 18Last Post: 15-08-2008, 12:09 AM -
PC for animation
By tarundham in forum Hardware Q&AReplies: 9Last Post: 29-04-2008, 04:52 PM
LinkBack URL
About LinkBacks
