Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 26-06-2005, 07:17 PM   #1 (permalink)
The CREATURE
zodiac_511's Avatar
Default Will this Config work ?
I'm purchasing a new system 8)
CPU =AMD Athlon64 (939 pin) 3800+
MOBO =MSI K89 Diamond
RAM =512 MB (DDR 400 Mhz)
HDD =80 GB SATA (Seagate 7200 rpm)
Monitor =Philips 109 P4 (19in)
Graphics Card=PowerColor Radeon X800XL / Ati Radeon X850
1. Is the CPU available in Chennai and is the 4000+ available in Chennai now?
2. Which GFX Card shud i choose (Main Use :Gaming) ?
3. Are both the GFXs cards PCI-e based ?
..::: ||ZoDiAc|| ::..
zodiac_511 is offline
Old 27-06-2005, 02:30 AM   #2 (permalink)
The Hardware Labs
mohit's Avatar
your config is mindblowing dude.
1. Availability cant be guaranteed by i doubt its available in india. maybe u ll have to get it ordered or something.
2. U are buying a SLI mobo and you are going for ATI cards ? that will not work. go for 2*Gainward 6800 Ultra 256 mb golden samples pci-e ... and u will have a monster of a system.
Also i suggest go for a 160 gb sata n.c.q hdd (seagate) or even better go for 2*80 gb seagate sata n.cq's in raid 0. Also go for a Samsung 19" Magic bright monitor. its good.
mohit is offline
Old 27-06-2005, 11:36 AM   #3 (permalink)
dinesh_singh
Posts: n/a
3800+ not available.....
800xl is available with mediatech
sli mobo not a good choise for 800xl
Old 27-06-2005, 11:41 AM   #4 (permalink)
expertno.1's Avatar
dude mine one suggestion is to get more hard disk space..80 gb is not enogh.....at least 120 gb..
for cards read the January 2005 digit magazine
expertno.1 is offline
Old 27-06-2005, 11:54 AM   #5 (permalink)
QA Juggler
saROMan's Avatar
also wud suggest get more Ram ..without RAM its like Driving a Ferrari with no Tyres....Go 4 least 1GB DDRII@577Mhz(if available)..and 2GB if u can afford.....
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 03-07-2005, 12:37 PM   #6 (permalink)
The CREATURE
zodiac_511's Avatar
@ Mohit
Are u trying to say tht the GFX card wont work @ all with the mobo?
@ saRoman
does this mobo support DDr II Ram?
Old 04-07-2005, 02:30 PM   #7 (permalink)
The Hardware Labs
mohit's Avatar
Originally Posted by zodiac_511
@ Mohit
@ saRoman
Ati cards wont work in SLI mode with this board. Also for your info , AMD processors do not suuport DDDR-II.
mohit is offline
