Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 12-03-2009, 10:40 AM   #1 (permalink)
sav_more's Avatar
Question Please help me configure a new PC upto 20K
Hi Guys,
I need to get a new PC configured.
I would prefer an AMD config.
Main use will be light gaming on mid settings and movies.(external grafix card will be preferred)
My budget is around 20K max.
I already have 120GB hdd seagate.
zebronics LAVA cabinet with 500W PSU.
i also have a 15 inch CRT.(but if i can fit an LCD within this budget, then nothing like it).
creative 5.1 speakers.(no need to replace).
I have seen this config in this forum somewhere by desiibond, pls suggest if this is good enough.
AMD Phenom 8650 - Tri Core
Gigabyte GA-MA78GM-S2HP
2x2GB Corsair DDR 2
Thanks.
********tryin to use ubuntu......n lovin it*********
ASUS A8N VM CSM,AMD 3000+ @ 2GHZ,Seagate Barracuda 120Gb,256*2 ddr @400mhz,samsung syncmaster793mb,geforce7300le,samsung CD-RW,creative 4.1
sav_more is offline
Old 12-03-2009, 11:01 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Please help me configure a new PC upto 20K
if you are thinking of light gaming and more movies, go for the config that you mentioned. and with the extra 8k saved, get 19" Dell 198WFP (7k). That should be enough for you. Do not buy a GPU now as there is lot of price reduction happening in USA and is likely to take effect here. keep the amount saved and once the graphics card prices come down, add few more bucks and get the one that is best for the new LCD.
780G should be enough for light gaming!!!
desiibond is offline
Old 12-03-2009, 11:19 AM   #3 (permalink)
sav_more's Avatar
HI desiibond,
i am glad that you replied.
thanks a lot for the quick reply,
but i want to get everything in one go..i dont want to wait.
if the grafix card is really good, i could extend the budget to 25K.
but i dont want to upgrade anything for the next one to one and half year.
so more sugestions are welcome.
sav_more is offline
Old 12-03-2009, 12:59 PM   #4 (permalink)
toofan's Avatar
Gave a look at this thread. And try to follow desibond.
New CPU @20K
Check my work at:
http://www.flickr.com/photos/vimaljoshi
toofan is offline
Old 12-03-2009, 01:24 PM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
There are few more points that you need to consider
1) Phenom II 710 is released and is expected to hit Indian market. This is a really fast processor and competes with E8xxx Intel core2duos.
2) Heavy price cuts on GPU's by AMD and nVidia.
Old 13-03-2009, 09:55 AM   #6 (permalink)
sav_more's Avatar
New CPU @20K
HI,
Thanks for your reply , but that thread follows INTEL config.
I want to go for AMD.
Posted again:
Hi,
But will this take effect soon, cos i want to be ready by next week!!
And will it fit my budget of 20K-25K(MAX).
Also i would like to go for ATI for GPU.
sav_more is offline
