Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 05-02-2009, 06:25 PM   #1 (permalink)
techygeek's Avatar
Smile Pc config for 25k
Hi guys
my friend needs to buy a pc (budget 25k)and i advised him checking prices at 2 local reliable shops
Asus p5 n73 mobo--2350
Intel c2d e7300(2.66 Ghz)--5900
2Gb transcend ram--1300
250gb sata hdd seagate--2350
DVD RW Samsung--1150
Nvidia 8400gs--2350
Logitech combo--800
Any cabinet of his choice(1300-1700)
Speakers--450(Suggest some around 500)
19'' Viewsonic LCD--7250
Give ur comments and modifications for these under 25k
also should i buy 8400gs as the mobo has NVIDIA GeForce 7050
techygeek is offline
Old 06-02-2009, 07:25 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Pc config for 25k
C2D E7300 Rs. 5600
Asus P5KPl-CM Rs. 2300
2x 1GB Transcend DDR2 800Mhz Ram Rs. 1200
320 GB Seagate Sata HDD Rs. 2200
Samsung DVD RW Rs. 1100
Don't even Think of nvidia 8400GS ( it's only Rs. 1600 - your vendor is just duping you )
get 9500GT instead @ Rs. 3500
Zebronics Bijli with 400W PSu Rs. 1500
ToPsPeEeD = FaSt BuT StEaDy
topgear is online now
Old 06-02-2009, 06:52 PM   #3 (permalink)
techygeek's Avatar
Exclamation Re: Pc config for 25k
Do u know any shop in mumbai where i can get the parts at ur mentioned prices
Old 06-02-2009, 09:41 PM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
Buddy I'm from kolkata not from mumbai. I've heard there are some good shops in lamington road. Ask someone from your city. They can help much.
You can also try Prime ABGB or Theitwares. Just call them & verify about the prices.
http://www.theitwares.com/contactus.htm
http://www.primeabgb.com/
Wi-Fi Config.............. myharshdesigner Software Q&A 1 20-07-2007 10:33 AM
help with pc config.. ashwin_ka PC Components / Configurations 4 18-07-2007 09:23 PM
Plz suggest new config.. (update on already referred config) xsreality PC Components / Configurations 48 02-06-2007 04:08 PM
Which config to go for.... jay4u PC Components / Configurations 20 08-01-2006 08:56 PM
PC Config mAYHEM QnA (read only) 9 11-04-2005 10:06 PM
