Results 1 to 5 of 5
  1. #1
    May 2008
    Exclamation Pls take a look at this config!!
    Hi,
    Below is the configuration which I have chosen after careful consideration. Please give me your feedback and suggestions. My Budget is 24000. I checked the bwindia.com website for the prices. I believe the street prices will be 500 to 1000 lesser, hope fully ... If you can give me a price for the h/w i'll be very grateful. I live in Bangalore and planning to get this config at S.P Road by Dec 10th.i have not checked the prices there yet, but will do it soon.
    Intel Core 2 Duo 2.53 Ghz 1066Mhz FSB
    Mercury Intel 945 GCM 1333 FSB
    Cabinet Gigabyte or iBall Advanced [ budget 1200 - 1500 ] if i get them!! Basically want a spacious Cabinet.
    DVD Writer LG Sata
    RAM DDR II ZION 800 Mhz 2 * 1 GB
    SMPS Mercury 450 W 24 Pin
    External Hard Disk Maxtor 2.5" 160 GB
    Internal Hard Disk Western Digital SATA 80 GB
    basic keyboard & Mouse
    iBall Speaker basic Woodpecker
    Graphics Card ?? I am stumped!! I am not sure, please help me with this.
    I am not a hardcore gamer. Chessmaster 10 is the only game i play these days !!
    Suggest a basic Graphic Card! I read the Digit issue of entry level graphic cards but don't want to go beyond 24000 bucks.
    What about an Integrated Graphics Card?
    If I have missed anything out please let me know! Also pls list out what basic accessories that I will definitely need
    Thanks in advance for your time.
  2. #2
    Caballero de Real Madrid m-jeri's Avatar
    May 2004
    Trivandrum\God's Own Country
    Default Re: Pls take a look at this config!!
    get a new architecture...AVOID 945.....
    get a cheap p35 .... and get Transcend RAMS... well if ur max game is chess..then stick with IGP... no need....
    and look for VIP..or another brand...atleast a iBall
    and how about this config in total...
    Motherboard: Gigabyte GA-G31M-S2L 2.15k
    Processor: Intel Pentium Dual Core E2180 2.9k
    RAM: Transcend 2x1GB DDR2 800MHz 1.7k
    GPU: Xpert Vision HD 3650 512MB 3.2k ----> U can avoid this if u want
    HDD: Seagate 250GB ST3250310AS SATAII 2.3k
    Cabinet & SMPS: CM Elite 330 + CM Extreme Plus 460W (Combo) 3.7k
    Optical Drive: L.G. H62N 20x IDE / Samsung 203B/D 20x SATA 1.2k
    Speakers: Creative Inspire 2.1 M2600 1.8k
    Monitor: ViewSonic 19" VG1930WM / Dell SE198WFP / L.G. L194WT 8.5k
    Keyboard: Samsung Pleomax .2k
    Mouse: Logitech Optical .4k
    |PC-15R-i3 M530|3GB DDR3|320GB|5470 512MB|500 GB Ext|D/L-D410PT|1GB|500GB|E122|APEX MI - 100|A/V-E2200HD|PS3 80GB+AT90USB162|Z5500 D|10TB|MOMO Wheel|APC 1KV|Click-500D|18-55 IS|
  3. #3
    May 2008
    Thanks for the reply
    I am warming to the config you sent...
    Do I really need a 19" monitor.. Don't you have to sit quite far from the monitor if you are watching movies are playing games on a 19 " ??
    Motherboard: Gigabyte GA-G31M-S2L 2.15k seems to be a good option..
    My reason for going for a 80m GB internal was all i want for the HD to do is for Win XP and Ubuntu.. and space for installing applications..
    Movies , Songs and Softwares and etc etc I would definitely want it to be portable!! Copying it to my pen drive and deleting again & again is a drag!! So I thought of an Xtern HD!!
    How is the option of getting an 3.5" HD and a Case for it??
    Why did you suggest a Dual Core Processor?? Isn't a C2D better than Dual Core??
  4. #4
    May 2004
    1. Its a far better config than u specified... by dec 10..maybe the price may get better too
    2. 19" issue??... i dont think so mate.. get the 19"..ull thank later i am sure..
    3. Yes...Mobo is a VFM
    4. Nope... Get the 250 ..or atleast 160 GB min... u can do a lot of OSes or anything..the price ratio just dont agree for a 80 GB...
    5. C2D and Dual Core both same mate ..... relax...
  5. #5
    May 2008
    Unhappy Re: Pls take a look at this config!!
    Ok cool !! I'll tweak my config !! I'll let you know about the progress ! cheers..
    Hey dude!!
    One more query...
    Regarding Installing WinXP Pro!!
    Like I told you I would be installing Win XP on the 250 gig HD u suggested..
    The problem is my Original WinXP is without SP2...
    Does the motherboard u suggested come with SATA Drivers or something like that
    Mobo : Gigabyte GA-G31M-S2L
    If it does is it pre-installed or floppy based...
    I read that you have to detect the SATA HD with BIOS then press F6 then install drivers for SATA then Install WinXP... If possible pls tell me the steps in a little detail so that I don't mess up..
  1. is this basic rig config right? also recommend a PSU and UPS for this config
    By CommanderShawnzer in forum PC Components / Configurations
    Last Post: 23-04-2012, 08:06 AM
  2. Gta 4 Config
    By soyab0007 in forum Gamerz
    Last Post: 20-02-2009, 09:40 PM
  3. Plz suggest new config.. (update on already referred config)
    By xsreality in forum PC Components / Configurations
    Last Post: 02-06-2007, 04:08 PM
  4. PC config
    By hingepradeep in forum PC Components / Configurations
    Last Post: 07-11-2006, 09:28 AM
  5. help 4 config
    By varunprabhakar in forum PC Components / Configurations
    Last Post: 22-10-2006, 03:52 PM
