| Forum |
| PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting. |
#1 (permalink) |
I have a budget of 15k max, and with it, i want to purchase a processor, motherboard, and RAM.. This comp will be used mainly for internet surfing, and watching movies. My friends tell me that for this price range, AMD offers the best value for money, so i thought i'd go ahead with it.. Which is the best Proc-mobo combination i can get for my money? |
#2 (permalink) |
for a budget of 15 k ... u can get a great combination of Proccy-Mobo-RAM
I can suggest u the following configs : Dual Core Configs: E7200/E8200 from Intel -- 5.8 k/ 8.2k XFX 630i Mobo / Asus P5k VM- 3.5k / 5k 2GB 800 Mhz Kingston/corsair -- 1750-1900 AMD Configs: Tri Core Config AMD x3 8750 -- 7k Gigabyte GA-MA78GM-S2H -- 5k (best mobo for your use with loads of features like HDMI, Esata, HD playback etc ) 2GB 800 Mhz Kingston/corsair -- 1750-1900 Quad Core Config AMD X4 9550 -- 7.5k Gigabyte GA-MA78GM-S2H -- 5k 2GB 800 Mhz Kingston/corsair -- 1750-1900 If you are not much into heavy Gaming ( i assume coz u didnt asked for Grafix card ) Both the AMD Configs wld be better for u (in terms of features and performance) and the Last config wth Quad Core Phenom is the best bet in ur budget (superb mulittasking in that budget with an awesome Motherboard) . Your choice now ...
Wats the Favourite Mathematical Function of DIGIT FORUM ???? They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!! |
#3 (permalink) |
Hey, thanks a lot..!
When i asked my vendor, he said the 9550 costs around 8k.. moreover, i dont need to do a lot of multitasking on this machine.. the aim here is to keep costs as low as i can.. How's the Athlon series now? I mean, after the introduction of the X4, does it still make sense to buy one? As for the mobo, i was looking at the Asus M3A78EM, but it seems to be unavailable right now.. The reviews on the gigabyte board look promising.. hmm.. Looks like that's decided then.. |
#4 (permalink) |
Excessive happiness
C2D E7200 - 6k
MSI P45 Neo F - 6k 2GB DDR2 Transcend - 1.7k Total 13.7k.... For AMD Rig,, I suggest u to go for what harryneopotter suggests..
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ Addicted to Game Dev & Grand Prix Story |
#5 (permalink) |
@rajkumar_pb ....
dude i know that P45 Neo F is an awesome board ... but u cant blindly suggest this board to anyone .... this board doesnt have onboard grafix and i dnt think that the OP need to spend more on a dedicated card for his moderate usage. According to his moderate usage ( i dont think he will overclock either for surfing or Movies .. so i suggested 630i and P5kVM ) ... no offence if i sounded rude or sumthing like that ... @ Shirazhansen If u dnt want X4 ... then Phenom X3 8450 at 5k will be the best bet for u ..... it a tricore proccessor running at 2.1 Ghz .... it will surely rock ur system for moderate mulittasking . And the Gigabyte Board is the best in its budget ... but make sure that u get the latest version (Ver 1.1).
#7 (permalink) | |
Excessive happiness
Anyway, i prefer XFX 630i and ASUS P5K PL VM /CM just as harryneopotter...
#9 (permalink) |
I guess that'd be the case no matter when i buy it!
By the way, i need a mobo with decent onboard graphics.. this is gonna be like a second computer, to be used largely for internet browsing and the occasional movie.. so i'm not gonna buy a graphics card for it.. I checked the Gigabyte board.. but even that is unavailable.. ! Just my luck! Are there any other good Asus boards that have onboard graphics? |
#10 (permalink) |
Excessive happiness
^^ Already mentioned... ASUS P5K PL VM/CM
#11 (permalink) |
Oh.. i thought the Asus P5K PL VM/CM was best suited for an intel proccessor.. Is it gud for AMD too?
I thought motherboards were processor specific.. am i wrong? |
#12 (permalink) | |
Violent serenity.
o_0... Google too hard to use
@OP :- Go with harryneopotter's Quad config. Its the best VFM in ur budget. Otherwise, you can get this :- E7200 2Gb Transcend DDR2 800MHz RAM ASUS P5K VM Quote:
BTW, if u dont need heavy multi-tasking, then u can get an E2160, ASUS P5K PLVM, 2GB RAM and a 9400GT. This way, you will able to see any HD videos on ur PC without any stuttering. AMD alternate :- AMD x2 4400+ 2GB RAM Jetway 780G mobo (The IGP is powerful enough).
Registered pwner of theists, noobs, posers and emos. Last edited by Psychosocial; 16-11-2008 at 10:05 AM. Reason: Automerged Doublepost |
#13 (permalink) |
Bond, Desi Bond!
1) Intel E8400: 8k
2) ASUS P5kVM :5k 3) Kingston/transcend DDR2 800 2Gb : 1600 for AMD: harryneopotter's config is great
My first blogspace: http://desiibond.blogspot.com Last edited by desiibond; 16-11-2008 at 10:29 AM. Reason: Automerged Doublepost |
#14 (permalink) |
If you have a computer which is powerful enough why spend much on a second PC. go for AMD X3 Or even AMD X2 6400+, they are good enough for movies and browsing (with 1 or 2 gigs of RAM).
Digital Sheets Technology Blog AMD Phenom II X4 840, 4 GB RAM, MSI HD5670, Corsair CX400 PSU Nokia 5230 Canon IXUS 115 HS |
#15 (permalink) | |
Ok, I've decided to go ahead with Harryneopotter's config.. without the quad, though, since it's both expensive (8.5 now) and unavailable (!).. So now it's an X2 6400+ proc, GA-MA78GM-S2H for the mobo and 2 GB Kingston.. Thanks a lot for the help guys.. Sure appreciate it.. Last edited by shirazhansen; 20-11-2008 at 08:40 PM. |
#16 (permalink) | |
The Smaller Bang
http://TheSmallerBang.wordpress.com eMachines E725 - T4400 2.2GHz, 1GB, 160GB Nokia 5130XM * T-Sonic 610 2GB Nokia 2323C * Samsung Galaxy Y Apple iPad 2 16GB WiFi |
#17 (permalink) |
AMD 6400+ is almost 7.5k .... if u can ... opt for X3 (tricore) ranging from 5k (X3 8450) to 7.5k (X3 8750) ...this will be better VFM in my opinion.
#18 (permalink) | ||
I did enquire about the X3, but it seems to be out of stock.. actually, the whole phenom range is hard to get.. tried gettin an X4 9550 for a friend, but same problem.. It's probably just my location.. i know i might get it frm Chennai or B'lore.. but i need to get it thru my local vendor (for service), and he sez he cant find any.. so i really dont have a choice.. Quote:
The reviews on this seem gud.. any idea how much it costs? i couldnt get the local price..
Core-2-Quad 6600 @ 2.4GHz, P5N-E-SLI, 2X2GB Zeon, 650W Corsair PSU, Gecube ATI-Radeon HD 4850, 20" Samsung LCD. Last edited by shirazhansen; 24-11-2008 at 02:55 AM. Reason: Automerged Doublepost |
#19 (permalink) |
IF you are only going to use it for internet and occasional movie, then a cheap 4200 x2 with 1/2gb ram will be enough. Get any 780g board if you can. Those X3s with low frequencies are not worth the buy IMO. I'm using 4200 with 9600gt and it runs all games well, though it has some processor bottleneck. Buy a cheap processor with 780g chipset so that you can upgrade processor to phenom 2 when it becomes cheaper.
X2 4600 is 2900 X2 6400 more than 6000. Think of the price diff of 3000 just for for browsing and movies is worth. You won't see any diff anyway for that kind of use. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Is configuring paid DTH possible?? | abhi.eternal | PC Components / Configurations | 4 | 16-02-2008 11:23 AM |
| Configuring two HDD's | GeekyBoy | PC Components / Configurations | 4 | 24-03-2007 02:26 PM |
| configuring net on ubunutu | dhawald | Open Source | 6 | 26-10-2006 03:39 AM |
| Please help....Configuring E61 for WLAN... | prathap_lab | Mobiles and Tablets | 2 | 08-10-2006 10:40 PM |
