Old 15-10-2008, 05:28 PM   #1 (permalink)
Default Opensuse 11 not detecting my graphics card
I tried to install opensuse 11 using the DVD which i got with linux for you on my laptop.
The installation completed successfully and after booting in to suse, the screen went blank
I tried once again and this time I selected manual configuration for Yast. At the beginning Yast configuration, it says GUI cannot be loaded because the graphics card is not supported. so going in to text mode.
I have a Dell studio 1530 laptop with the following configuration
Intel core 2 Duo 8100, 3 GB RAM, ATI Radeon HD3450
plz help
sarincv is offline
Old 15-10-2008, 06:13 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: Opensuse 11 not detecting my graphics card
Press Ctrl+Alt+F1
login
type su and press ENTER
Now type
sax2 -r
and press ENTER and configure your display
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 15-10-2008, 06:19 PM   #3 (permalink)
k..I will try this after reaching home.....
what actually the problem is???
sarincv is offline
Old 15-10-2008, 09:06 PM   #4 (permalink)
Resistance is Futile.
coolpcguy's Avatar
ATi cards can be a real pain, from what I've heard
Super User ♦ Moderator | chip/tech2 forum Mod | About me
Gadgets: HP Envy 14 | Google Cr-48 | D-Link DGL 4500 | Denon AH-C360 | Fiio E5 | Galaxy SII GT-I9100 | Dell U2312HM
coolpcguy is offline
Old 15-10-2008, 10:08 PM   #5 (permalink)
TheSaint
^+1
Oh yes they are
I do not have an ATi card so cannot make it any easier
If you find difficulty inspite of going through the above method try this
http://forums.opensuse.org/how-faq-r...i-drivers.html
It's an APPROVED how-to on ATi drivers
Old 15-10-2008, 11:03 PM   #6 (permalink)
BSD init pwns System V
hellknight's Avatar
yeah.. ATI Cards suck on Linux.. it doesn't accelerates the graphics on my system.. ATI X1250.. runs well with 8800GT though
My blog :- www.openenclave.wordpress.com
hellknight is offline
Old 16-10-2008, 08:55 AM   #7 (permalink)
I tried 1st method suggested by NucleusKore but nothing happens.... I installed Mandriva spring 2008 yesterday... its having the same problem.... display goes blank.... now my vista also gone.... in the boot menu, windows is der but its not getting booted....some dell system testing tools are running....
sarincv is offline
Old 16-10-2008, 07:41 PM   #8 (permalink)
TheSaint
Please see that ATi howto in opensuse forums. I have posted the link above
Old 17-10-2008, 05:24 PM   #9 (permalink)
now i installed mandriva 2008 over that... its detecting the graphics card but no sound.... the sound device for my laptop is IDT 92HD73C1.... will i get the linux driver for this???
sarincv is offline
Old 17-10-2008, 08:05 PM   #10 (permalink)
TheSaint
Start a new thread
Old 12-11-2008, 03:17 PM   #11 (permalink)
Hi,
I have bought recently a DELL latitude E6500 laptop, and intalled Open SUSE 11. The problem I am facing is that the graphic drivers are not working properly.
I do not know if the graphic card is detected at all or not?
The garphic card is Nvidia Quadro NVS 160M 256 MB DDR3.
please suggest me wht to do?
thanks in advance.
pandeycs is offline
Old 12-11-2008, 06:24 PM   #12 (permalink)
TheSaint
Use the one click install here (green)
http://en.opensuse.org/Nvidia
After installing press ctrl+alt+del
ctrl+alt+F1
sign in as root and give root password
type
sax2 -r
and press ENTER and configure your display and click ok to save.
press ctrl+alt+F7 and login
Old 12-11-2008, 11:42 PM   #13 (permalink)
Indidiot
Plasma_Snake's Avatar
Even my ATi HD4850 is not being detected and moreover neither is my Ethernet Card. My MoBo is ASUS P5QC, can anybody gimme Linux drivers for it. Its DVD has only Audio drivers for Linux in it.
Plasma_Snake is offline
Old 13-11-2008, 01:07 AM   #14 (permalink)
4T7
4T7's Avatar
Install the official ATI driver available on AMD's website and as far as NIC goes its an ATHEROS, so u shud check vendor's website but check ASUS's site first
4T7 is offline
Old 13-11-2008, 12:57 PM   #15 (permalink)
ctrl+alt+F1
Thanks a lot. It is working now.
pandeycs is offline
Old 13-11-2008, 01:24 PM   #16 (permalink)
Indidiot
Well my trouble haven't ended, I got the LAN and Audio drivers from ASUS's site but don't know how to install them. I want to install only the LAN drivers. I've got these 2 files which aim to guide the installation procedure but I don't understand it, as of now;
Old 13-11-2008, 08:38 PM   #17 (permalink)
TheSaint
The easiest workaround for the above problem is to:
1. Borrow and install a regular realtek lan card (not the gigabit one).
2. Run a online update, the drivers will be downloaded and installed
3. Remove and return the card
Old 14-11-2008, 08:54 PM   #18 (permalink)
Indidiot
I just need to know as to how to compile the source code that I've got for my Audio and LAN drivers, in Open SUSE 11? If u can't then atleast direct me to a link regarding it. Please!
Old 15-11-2008, 03:58 PM   #19 (permalink)
TheSaint
Can you give me the link to the tarball you downloaded
Old 15-11-2008, 04:36 PM   #20 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
If this was Ubuntu I could link you a post I read over a while ago. You can access it here . It shows the process the person used for getting it installed on Ubuntu . Maybe you and Nucleuskore can come up with an alternative solution for OpenSuse after reading this.
Hope it helps.
FilledVoid is offline
Old 15-11-2008, 07:30 PM   #21 (permalink)
Indidiot
I got the drivers from ASUS's site, here's the link
BTW its ASUS P5QC, P45 chipset based MoBo supportin 16GB DDR2 and 8GB DDR3 RAM!
Old 15-11-2008, 08:01 PM   #22 (permalink)
TheSaint
Hope it helps.
My exposure to ATi is nil. That's the whole problem. It does not appear to be as simple as NVidia (see above solution). That's why you have so many claims of "good" methods to install ATi drivers, all over the internet
Old 23-11-2008, 03:54 PM   #23 (permalink)
Indidiot
OK, here is the Mediafire link to the zip file containing both my Audio and LAN drivers, for Linux, its a 8.73 MB file. Please tell me how to install these drivers in my OpenSUSE 11 (x64).
http://www.mediafire.com/file/inwe0ttmtwu/LinuxDrivers.zip
Old 23-11-2008, 04:59 PM   #24 (permalink)
TheSaint
I did get the file from the manufacturers website. Installation is not very straight forward I'm afraid. Like I said, get a regular lan card at least temporarily, and run a suse update. It should automatically load the drivers for your onboard lan and audio
My graphics card not Supporting Turbo C++ graphics plz help Maxx32 Graphic cards 1 19-06-2008 12:39 AM
motherboard not detecting LAN card anarchy0x Software Q&A 4 16-06-2007 01:43 PM
Query Reg Graphics card/TV Tuner card tiwariG QnA (read only) 10 10-09-2004 06:38 PM
- by gforz
- by soumya
