your xorg.conf is missing the AddARGBGLXVisuals extension.
add the AddARGBGLXVisuals, RenderAccel and composite extensions. add them.
here's my xorg.conf.
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildmeister@builder3) Wed Nov 14 17:10:54 PST 2007
# SaX generated X11 config file
# Created on: 2007-12-01T04:05:07+0530.
# Version: 8.1
# Contact: Marcus Schaefer <sax@suse.de>, 2005
# Contact: SaX-User list <https://lists.berlios.de/mailman/listinfo/sax-users>
# Automatically generated by [ISaX] (8.1)
# PLEASE DO NOT EDIT THIS FILE!
Section "ServerLayout"
Identifier "Layout[all]"
Screen "Screen[0]" 0 0
InputDevice "Keyboard[0]" "CoreKeyboard"
InputDevice "Mouse[1]" "CorePointer"
InputDevice "Mouse[3]" "SendCoreEvents"
Option "Clone" "off"
Option "Xinerama" "off"
EndSection
Section "Files"
InputDevices "/dev/gpmdata"
InputDevices "/dev/input/mice"
FontPath "/usr/share/fonts/misc:unscaled"
FontPath "/usr/share/fonts/local"
FontPath "/usr/share/fonts/75dpi:unscaled"
FontPath "/usr/share/fonts/100dpi:unscaled"
FontPath "/usr/share/fonts/Type1"
FontPath "/usr/share/fonts/URW"
FontPath "/usr/share/fonts/Speedo"
FontPath "/usr/share/fonts/PEX"
FontPath "/usr/share/fonts/cyrillic"
FontPath "/usr/share/fonts/latin2/misc:unscaled"
FontPath "/usr/share/fonts/latin2/75dpi:unscaled"
FontPath "/usr/share/fonts/latin2/100dpi:unscaled"
FontPath "/usr/share/fonts/latin2/Type1"
FontPath "/usr/share/fonts/latin7/75dpi:unscaled"
FontPath "/usr/share/fonts/baekmuk:unscaled"
FontPath "/usr/share/fonts/japanese:unscaled"
FontPath "/usr/share/fonts/kwintv"
FontPath "/usr/share/fonts/truetype"
FontPath "/usr/share/fonts/uni:unscaled"
FontPath "/usr/share/fonts/CID"
FontPath "/usr/share/fonts/ucs/misc:unscaled"
FontPath "/usr/share/fonts/ucs/75dpi:unscaled"
FontPath "/usr/share/fonts/ucs/100dpi:unscaled"
FontPath "/usr/share/fonts/hellas/misc:unscaled"
FontPath "/usr/share/fonts/hellas/75dpi:unscaled"
FontPath "/usr/share/fonts/hellas/100dpi:unscaled"
FontPath "/usr/share/fonts/hellas/Type1"
FontPath "/usr/share/fonts/misc/sgi:unscaled"
FontPath "/usr/share/fonts/xtest"
FontPath "/opt/kde3/share/fonts"
EndSection
Section "Module"
Load "dbe"
Load "type1"
Load "freetype"
Load "extmod"
Load "glx"
EndSection
Section "ServerFlags"
Option "AllowMouseOpenFail" "on"
EndSection
Section "InputDevice"
Identifier "Keyboard[0]"
Driver "kbd"
Option "Protocol" "Standard"
Option "XkbLayout" "us"
Option "XkbModel" "microsoftpro"
Option "XkbRules" "xfree86"
EndSection
Identifier "Mouse[1]"
Driver "mouse"
Option "Buttons" "5"
Option "Device" "/dev/input/mice"
Option "Name" "Broadcom USB Mouse"
Option "Protocol" "explorerps/2"
Option "Vendor" "Sysp"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Mouse[3]"
Driver "synaptics"
Option "Emulate3Buttons" "on"
Option "InputFashion" "Mouse"
Option "Name" "Synaptics;Touchpad"
Option "SHMConfig" "on"
EndSection
Section "Modes"
Identifier "Modes[0]"
ModeLine "800x600" 38.2 800 832 912 1024 600 601 604 622
EndSection
Section "Monitor"
Identifier "Monitor[0]"
VendorName "DELL"
ModelName "1280X LAPTOP DISPLAY PANEL"
UseModes "Modes[0]"
DisplaySize 332 207
HorizSync 31.0 - 90.0
VertRefresh 59.0 - 75.0
Option "CalcAlgorithm" "XServerPool"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device[0]"
Driver "nvidia"
VendorName "NVidia"
BoardName "GeForce 8600M GT"
EndSection
Section "Screen"
Identifier "Screen[0]"
Device "Device[0]"
Monitor "Monitor[0]"
DefaultDepth 24
Option "RenderAccel" "True"
Option "AddARGBGLXVisuals" "True"
SubSection "Display"
Modes "1280x800" "1280x768" "1024x768" "1280x600" "1024x600" "800x600" "768x576" "640x480"
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
Depth 32
EndSubSection
Depth 8
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSection
If this doesnt work ,Are you installing the drivers via Restricted driver manager ? Try the manual install of drivers - it will remove all existing drivers and install again. To install manually, get the .run file of the driver from nvidia's site. you will need kernel-header and kernel-sources as well.
Copy the .run file to your home directory. Open the terminal, switch to console mode by typing
and once in console login, switch to your home directory, exec the run file using
sudo sh <name-of-run-file>
