06-10-2008, 11:45 PM
Violent serenity.
Some problems with Ubuntu
Ok so I installed Ubuntu after much thought. Now all the text on my Fire Fox browser is blurry and its a pain in the ass to read anything on net. How to fix it ? And the sound is also messed up. The songs are all flat pitched and bass is not good. I suppose it needs some kinda drivers so whats the name of that driver. Please tell me so I can install then via the Synaptic thingy  .
One more thing --> How do we install Last.fm plugin. Please help me on this atleast. My Top Listener feat. of Slipknot on Last.fm will be lost  .
07-10-2008, 10:30 AM
Re: Some problems with Ubuntu
which music player do u use?
i`d suggest exaile
sudo apt-get install exaile
then goto edit->prefs->Last.fm
even the default music player i.e rhythmbox supports last.fm , open its plugin menu and install last.fm
07-10-2008, 10:40 AM
Violent serenity.
Thanks. Got the last.fm thingy working. What about the other problems ?
One more thing......how do I add Ubuntu to XP's boot menu ?  .
07-10-2008, 02:01 PM
Pee into the Wind...
Not possible on XP's bootloader.You will have to use GRUB for that.
Life is as complicated as you say it is.
07-10-2008, 02:06 PM
Violent serenity.
^^Sh1t  .
07-10-2008, 03:44 PM
Zomg !
07-10-2008, 04:04 PM
Violent serenity.
No worries......I got rid of it (it = Ubuntu).
07-10-2008, 04:21 PM
Time to close the thread
07-10-2008, 08:46 PM
TheSaint
For your font problem install liberation fonts via synaptic and set them as your system fonts.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
07-10-2008, 09:53 PM
Violent serenity.
Hey NucleusKore......is there ANY way I can add Ubuntu to my XP bootloader......please......PLEASE coz I have customised Ubuntu's desktop and installed 400+MB of updates  .
07-10-2008, 09:59 PM
just install grub naa
07-10-2008, 10:13 PM
Violent serenity.
how ?
07-10-2008, 10:41 PM
TheSaint
How did you install Ubuntu without installing GRUB???
07-10-2008, 10:58 PM
Violent serenity.
How do I installing it again ? I mean if want to install it separately, what should I do ?
07-10-2008, 11:05 PM
Section Moderator
jus format the linux partition n reinstall from live cd i guess.............i installed mandriva using live spring cd................there is GRUB bootloader that comes after installing in a specific partition(seperate not xp one)............don forget to add xp as as n option in the other OS choice of GRUB...
07-10-2008, 11:18 PM
http://www.gnu.org/software/grub/man...-natively.html
or
http://ubuntuforums.org/showthread.php?t=224351
thats the noob way to do it
07-10-2008, 11:35 PM
Violent serenity.
Well if wanted to format then I would have not asked the question in the first place  .
Originally Posted by hullap
THANKS.....thanks a lot dude......that forum link really helped !
Reason: Automerged Doublepost
12-01-2009, 01:55 AM
ntldr doesnt support non-win operating systems....but theres way u can add
http://www.vsubhash.com/writeups/multiboot_os.asp
add xp to grub makes sense
The new digIT forum with all those adds sucks!!! Learn some adsense.
12-01-2009, 08:31 AM
#19 (permalink)
I don't what you liked about that black scrren
GRUB can be modified for various looks .. How to : Install GFX Grub In Ubuntu !
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
12-01-2009, 02:48 PM
#20 (permalink)
Married!
Its so simple, install grub and it will have entries for Win XP as well as Ubuntu.
Teri problem kya hai? Just give some commands in terminal and restore grub to your mbr and it will automatically make an entry for XP.
How to restore Grub from a live Ubuntu cd
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
