Before I get into my problem, a little background, have a Dell 1520, 160GB HDD, of which 130 GB is allocated as NTFS in 2 drives, 115GB as C, and rest as E.(D is for DVD RW)
the remaining 18GB is allocated to openSUSE, with 2GB swap, and rest 16 GB as a LVM, with /boot, / and /home as the LV's
Now recently I "upgraded" from XP to Vista, and that has screwed by my partition table BIG time
Check the picture below
so basically my 15GB Windows partition is "marked" as extended partition, Windows partition AND as my /boot LVM ALL at the same time. :-\
as a consequence, by /boot partition doesnt get mounted, (and can't mount manually either).
The only way to boot into openSUSE right now is to boot via openSUSE DVD, goto installation mode, choose other options and then choose Boot installed partition.
Unfortunately this doesnt mount my /home partition, and it fallsback into a bare-minimum root shell. I've to manually mount my /home partition, after this I can go into init 5. Even then none of the kernel modules are loaded
So after this lengthy explaination, how can I get this mess fixed ? anyway without having to reformat, repartiton etc etc?
And I have to boot using the DVD method, since the /boot partition doesnt mount AT ALL, I cannot use grub and write the bootloader
Any fixes ?
