Old 04-10-2008, 04:46 PM   #1 (permalink)
prasad_den's Avatar
Default Installed openSUSE 11.... need some guidance..!
Hi all,
After a very long time, I finally said bye-bye to my windows XP Pro SP3, and instead have installed openSUSE 11 in its place, along with Vista in a dual boot config..
Installation was a breeze.. it did get a little tricky at the partitioner level though. After some trial and error, I managed to set up my network correctly and have added an additional repository (Packman) also. I also managed to get my NVidia drivers installed properly, even though the one-click installation in the nvidia.opensuse.org site did not work out for me.. Now I think I have a good working linux system..
Now, I need some suggestions, guidance and advice from the expertise here, regarding some small problems and other sundry things..
1. Mine is a HP laptop with 160GB HDD and 2GB RAM. I have partitioned in such a way that the root is 10GB, swap is 1 GB and home is 4GB. Is there any problems in this setup..?
2. My windows NTFS drives are mounted and readable, but I need write access too. Please let me know how to assign permissions for the same. I'm the only user of my system.. no other user ids exist..!
3. Video files do not play... says something like invalid argument - could not be streamed.
Will post more queries here, as and when I get stuck somewhere.. Currently, I'm very much impressed with the simplicity that yast provides and so far I haven't used the CLI even once.. Hope that my date with Linux continues for a longer period and turns into love this time over..
P.S.1: Sorry for the long post..
P.S.2: Thanks in advance...
P.S.3: I would definitely recommend openSUSE 11 to a noobie...! Its really good.
prasad_den is offline
Old 04-10-2008, 06:01 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: Installed openSUSE 11.... need some guidance..!
Originally Posted by prasad_den View Post
Hi all,
After a very long time, I finally said bye-bye to my windows XP Pro SP3, and instead have installed openSUSE 11 in its place, .........
Welcome to the FUTURE
No, but /home the equivalent of Document and Settings folder in Windows. So you will have only 4 GB space to store your data. This can be alleviated by writing to existing ntfs partitions.
You have to install ntfs-config from the OSS repository and run it. It is very simple.
You will have to install Mplayer and w32 codecs from the Packman repository.
See this
Open SUSE 11.0 - Installing Software
http://www.thinkdigit.com/forum/show...php?p=947880#6
Frequently Asked Questions (FAQ's)
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 04-10-2008, 07:22 PM   #3 (permalink)
prasad_den's Avatar
Thanks for the prompt reply...!! Installed ntfs-config and now everything is fine with regard to writing in NTFS partitions.. And I had just installed mplayer.. No problems in media player also now..
Had gone through the FAQs earlier, but the other two links were useful.. especially your tutorials.
Career Guidance Help Plz ::cyborg:: QnA (read only) 4 21-11-2008 01:54 AM
Installed OpenSUSE 11 desktop effects not working... Kalyan Open Source 2 02-09-2008 09:04 PM
Installed OpenSUSE 10.3 Faun Open Source 4 27-03-2008 09:50 PM
CRT Vs LCD- need guidance mobileman Hardware Q&A 3 03-07-2007 09:02 AM
A little bit of Guidance!! Dilip Mallya QnA (read only) 4 29-05-2007 04:41 PM
- by gforz
- by soumya
