Old 04-10-2008, 02:49 PM   #1 (permalink)
Exclamation NTFS mount problems in Debian!!!
I run a XP-Debian(Testing) sytem! My XP-partitions are not accessible from Debian- I get a message that says-"cant mount media, u do not have proper permission!!" Any Help!!!!!
bob maddy is offline
Old 04-10-2008, 03:00 PM   #2 (permalink)
Default Re: NTFS mount problems in Debian!!!
Are u doing it as root?
ThinkFree is offline
Old 04-10-2008, 03:33 PM   #3 (permalink)
from terminal use mount command as root
man mount for further dig
Faun is offline
Old 04-10-2008, 07:15 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Use the ntfs-3g command to mount instead, and prepend sudo to your command
Example:
sudo ntfs-3g /dev/sda1 /mnt/Windows/C # Optionally, add -o force as an option
Harsh J
www.harshj.com
QwertyManiac is offline
Old 04-10-2008, 07:23 PM   #5 (permalink)
GaurishSharma.com
gary4gar's Avatar
or install ntfs-config via
sudo apt-get install ntfs-config
now run it via, ntfs-config
gary4gar is offline
Old 04-10-2008, 07:35 PM   #6 (permalink)
God of Mistakes...
Garbage's Avatar
ntfs-config is the best option seems here...
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 04-10-2008, 07:41 PM   #7 (permalink)
j1n M@tt's Avatar
if XP is in hibernated state....u can't mount NTFS partitions, this can happen to dual booting, usually v will forget whether v hav hibernated XP or not before booting to linux
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 04-10-2008, 07:48 PM   #8 (permalink)
Commander in Chief
I'm sure the force option would remove that issue.
Harsh J
www.harshj.com
Can't mount NTFS drive in ubuntu, Y ? saqib_khan Open Source 12 01-08-2008 11:48 AM
How to mount NTFS on Feisty? Dark Star Open Source 21 17-06-2007 09:55 AM
Unable to mount NTFS Partitions sachin_kothari Open Source 15 19-05-2007 07:45 PM
Mount NTFS in Ubuntu nishant_nms Open Source 4 07-12-2005 02:46 PM
Unable to mount all ntfs drives in fedora3.mount one ntfs, neerajvohra Open Source 1 06-02-2005 03:56 PM
- by gforz
- by soumya
