Old 01-10-2008, 12:11 PM   #1 (permalink)
Default Grub Problem-Urgent
Hi,
I'm running a xp ubuntu dual boot.Just after booting, i get the grub> promt . I'm stuck here ... can anyone tell me what to do ?
Thanks in advance
raviramgopal is offline
Old 01-10-2008, 01:04 PM   #2 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default Re: Grub Problem-Urgent
Does Grub give any error messages before you get grub> prompt.?
Post contents of file /boot/grub/menu.lst and output of command sudo fdisk -l.
Life is as complicated as you say it is.
shady_inc is offline
Old 01-10-2008, 06:00 PM   #3 (permalink)
TheSaint
NucleusKore's Avatar
looks like you grub got corrupted. Try to fix it with SUPERGRUB
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Grub Problem ! Dark Star Open Source 3 22-12-2007 10:42 PM
Grub bootloader problem.Help me its urgent utsav Software Q&A 1 18-11-2007 07:55 PM
urgent help needed on grub... amandeep2707 Open Source 1 16-12-2006 11:20 AM
Grub problem. LEARNER_LEARNER Open Source 1 29-11-2006 08:39 PM
Grub Problem plsoft Open Source 9 16-08-2006 09:35 PM
- by gforz
- by soumya
