Old 21-09-2008, 05:46 PM   #1 (permalink)
Default help in kubuntu 8.04
i recently installed kubuntu8.04 on my laptop.
now i am not able to see any windows on my panel once i minimize them. i have to alt+tab to switch between them. is there anyway to reset my panel or remove and recreate it?
also is there any way to change between powermanagement modes and get kubuntu to go to sleep when the battery is below a particular level.
simoncherian is offline
Old 21-09-2008, 07:41 PM   #2 (permalink)
God of Mistakes...
Garbage's Avatar
Default Re: help in kubuntu 8.04
Create a new panel.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 21-09-2008, 09:53 PM   #3 (permalink)
and then add some new items
Faun is offline
Old 22-09-2008, 09:56 AM   #4 (permalink)
unni's Avatar
You can right click on the panel, choose 'add new applet' and select 'task manager' or 'task tray'. I forgot the exact names, but you can get this option back from the 'add new applet' menu.
For powermanagement, search for battery/laptop in the repository. There is something named battery monitor (I think or it may part of some other package). I am using it. It has lot of options. In my opinion, it is better than the one in Windows Vista.
I can you give you the exact names by today evening (once I get to my PC).
unni is offline
Old 22-09-2008, 05:15 PM   #5 (permalink)
thank you guys.
all my probs sorted out
KDE 4.0.3 and Kubuntu Packages Are Now Available CadCrazy Open Source 2 04-04-2008 01:13 AM
Kubuntu help shaunak Open Source 6 09-11-2006 03:54 AM
Kubuntu Queries The Outsider Open Source 7 13-10-2006 12:45 AM
Now kubuntu free-cds!! chesss Technology News 1 19-05-2006 05:50 PM
WE WANT KUBUNTU DVD!!!!!!!!!! coolblue Open Source 2 16-10-2005 05:42 PM
- by gforz
- by soumya
