Old 20-09-2008, 01:05 PM   #1 (permalink)
Back!
red_devil's Avatar
Default ubuntu - gcc package problem
Guys, today i installed a copy of Ubuntu 7.04 { from a CD and not a DVD }... since the CD comes with limited packages, i'm having a problem with the GCC package.
i tried to run some sample C program to make sure the GCC was properly installed and when i tried to compile, i got an error message saying
error: stdio.h: No such file or directory
now i want to know how i can completely remove any existing GCC package and install GCC again so that i'm able to run any of the codes easily..
red_devil is offline
Old 20-09-2008, 01:20 PM   #2 (permalink)
Default Re: ubuntu - gcc package problem
^^Gcc follows standard C++, so header files are to be used without .h extension. Try with #include<cstdio>
ThinkFree is offline
Old 20-09-2008, 01:22 PM   #3 (permalink)
Back!
red_devil's Avatar
^^ nah not working... .getting similar error
Old 20-09-2008, 04:25 PM   #4 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
For C++,
#include<iostream>
using namespace std;
For C,
#include<stdio>
Apple iPad 2 16GB WiFi
MetalheadGautham is online now
Old 20-09-2008, 05:19 PM   #5 (permalink)
in search of myself
CadCrazy's Avatar
You have only installed gcc compiler and not the standard c header/lib files. To install all run following command in terminal
sudo apt-get install build-essential
Happy programming
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
CadCrazy is offline
Old 20-09-2008, 05:38 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
And the build-essential bundle can also be installed from the Installer/Live CDs, in case you don't have internet access on Linux.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 20-09-2008, 05:49 PM   #7 (permalink)
in search of myself
CadCrazy's Avatar
^^ Yes. Here's how
Insert cd in drive and enter following commands one by one
sudo apt-cdrom add
sudo apt-get update
Unban Praka123
CadCrazy is offline
Old 21-09-2008, 12:59 AM   #8 (permalink)
Back!
red_devil's Avatar
ah thanks guys...it worked...{ the online update thing worked.. the one suggested by CadCrazy didn't }
and btw me facing some newer problems... VI editor doesn't seem to be working fine... the insertion of text isn't happening properly... i guess some problem with the INSERT mode of the editor...any suggestions wrt this ???
Old 21-09-2008, 02:16 AM   #9 (permalink)
Wire muncher!
infra_red_dude's Avatar
Aah well.. happens sometime. Try using vim instead of vi.
infra_red_dude is offline
Old 21-09-2008, 09:08 AM   #10 (permalink)
The Smaller Bang
^^And if you are a n00b like me, use nano.
Old 21-09-2008, 09:14 AM   #11 (permalink)
Commander in Chief
infra_red_dude - I doubt if the vi he is using is classic, cause on most newer distros vi is a mere link to vim!
Harsh J
www.harshj.com
Old 21-09-2008, 09:15 AM   #12 (permalink)
OSS Enthusiast!
nitish_mythology's Avatar
Yeah..Even I am more comfortable with Nano.
Do you know, Shinigamis only eat apples???
nitish_mythology is offline
Old 21-09-2008, 09:51 AM   #13 (permalink)
Wire muncher!
@QM
Hmm... Point...
Old 21-09-2008, 08:43 PM   #14 (permalink)
Back!
red_devil's Avatar
@QM- i dunno if the VI i'm using is a classic version or not .. its the default thing that comes with Ubuntu 7.04 cd...
and how do i install vim ??
Old 22-09-2008, 03:37 PM   #15 (permalink)
The Smaller Bang
7.04 ? Then I think its vim. I used Ubuntu 7.04 for a whole year. It was my first distro
And yeah, you might want to try out nano if you want something without all those confusing shortcuts and what not. Its just a text editor, a plain and simple one, and feels like using notepad without mouse. Any actions like quiting, cuting, etc need you to use ctrl+key, with the keys being defined in the bottom of the window itself for you to see.
Offline Ubuntu Package Center CadCrazy Open Source 137 16-02-2009 04:13 PM
Ubuntu 8, Fedora 9 package OpenJDK CadCrazy Open Source 13 09-05-2008 11:56 PM
How to install rpm and .tx package in UBUNTU DukeNukem Open Source 11 01-11-2006 03:54 PM
Command to see dependencies of a package in Ubuntu vinayasurya Open Source 4 21-06-2006 12:09 PM
Problem with Windows Installer package Nariman Software Q&A 5 21-03-2006 01:42 PM
- by gforz
- by soumya
