| Forum |
#1 (permalink) |
1.initially i had 2xp's and vista installed, vith the vista bootloader as default. so whenever i booted, the vista oader would give a option "older versions of windows" that took me into the xp bootloader (ntldr) where i could choose betn my 2 xps. 2.one fine day i decided to install opensuse 11...n thought it necessary to replace vista bootloader vith xp(using the recovery console and fixmbr n fixboot) so that ntldr overwrote vistaldr..n then installed suse with its grub... now suse grub gave me 4 options like this -->suse11 -->suse11 (failsafe) -->windows1 -->windows2 and amazingly,windows 1 took me directly to the ntldr, while windows 2 took me to the vista loader! just what i wanted. 3. on another fine day, i decided i had enough of suse and deleted that partition and installed ubuntu hardy heron...with grub..but now my boot options looked like -->ubuntu -->ubuntu(memtest) -->other bootloaders -->vista/lonhorn the vista longhorn option took me directly to ntldr, where i could choose only betn xp. so now what i want is the setup similar to situation 2, only therell be ubuntu instead of suse...so how do i go about doin it (no pun here)guys?
#2 (permalink) |
TheSaint
If you know the partitions on which your your distros reside, windows and linux, all you have to do is
1. Install GRUB to the root (/) partition of Ubuntu 2. Install the GAG bootloader, see the end of this tutorial for instructions Installing Linux, a dual boot system with Windows and Linux If you do not know the partitions on which your your distros reside heaven help you.
http://www.neville.in http://www.linuxrocks.in "The Future Is Open" |
#3 (permalink) |
yup by a stroke of luck, i already installed grub on / partition of ubuntu
tried gag...but apart from floppy, it just shows me four other partition all windows/ ntfs...whole i have like 8-10 partition(4 on ist hdd(160 gig), 4-5 on 2nd(250 gig)) both xp's are on 1st hdd while vista n linux r on second
[ Last edited by sagar_coolx; 30-08-2008 at 10:50 PM. Reason: Automerged Doublepost |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Grub!! | arvi87 | Software Q&A | 6 | 02-06-2008 09:28 AM |
| Grub trubs | nithun | Open Source | 3 | 29-05-2006 11:13 AM |
| GRUB | champ_rock | Open Source | 1 | 07-10-2005 10:16 AM |
| GRUB | zerohourkill | Open Source | 28 | 28-04-2005 10:26 PM |
| Grub | bernie | Open Source | 8 | 17-11-2004 12:00 PM |
