Old 13-05-2005, 08:54 AM   #1 (permalink)
Default help me about sounds
hai
iam using linux but i cannot play sound.but i get video in redhat so i want they sound driver .where i get it .i use asus motherboard
prem is offline
Old 13-05-2005, 11:28 AM   #2 (permalink)
XMMS .... goto www.xmms.org and grab yo copy.
h4xbox is offline
Old 13-05-2005, 12:20 PM   #3 (permalink)
firewall's Avatar
@h4x I think he is facing issues with sound driver. not with any player.
@prem please post your distro and sound card details.
www.aloke.info
firewall is offline
Old 13-05-2005, 04:00 PM   #4 (permalink)
vignesh's Avatar
You have to install the xmms plugin for mp3 as for video you can use mplayer.Which version of redhat are you using?
vignesh is offline
Old 13-05-2005, 07:35 PM   #5 (permalink)
Which ver of redhat r u using?
Give details about ur chipset and snd card.
No one can help u without these details
amitsaudy is offline
Old 13-05-2005, 08:25 PM   #6 (permalink)
Which version of redhat is this?
Try using the following command in a terminal window (as root)
alsaconf
If alsaconf is present, it will try and detect your soundcard, and will ensure that the modules get loaded on booting.
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
- by gforz
- by soumya
