| Forum |
#1 (permalink) |
#2 (permalink) |
Commander in Chief
There are alternatives upto a possible-extent available in the ncurses libraries (Only available for POSIX systems). Link has a tutorial too, the basics are easy stuff
There are clear() and move() functions in ncurses that can help. Code:
man curs_clear man curs_move # For more help.
Harsh J www.harshj.com |
#3 (permalink) |
God of Mistakes...
or use system("clear"); or system("cls") which don't require any external lib. But thats not a good practice. But it servers the purpose !
Registered Linux User #468778 ---------------------------------- http://twitter.com/_Garbage_ |
#5 (permalink) |
include stdlib.h in your program.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 Samsung Omnia Pro B7610 with Stock WM 6.1 ROM Blog: http://www.sumitbhardwaj.co.in/blog |
#7 (permalink) |
Commander in Chief
"clear" will not always work cause Linux's method of clearing the terminal is different than Windows and will sometimes give you good WTF moments
system() not being found is very weird indeed, I have clue on this, but try including <stdlib.h> or <cstdlib> if C++...
#8 (permalink) | |
No error given be compiler with stdlib but still not clearing the screen.
#9 (permalink) |
God of Mistakes...
If using windows then try system("cls"); n if *nix then system("clear");
Actually, system() passes argument directly to shell...
#10 (permalink) |
Commander in Chief
Ah yes I did forget to include a "no". But system("clear") will not help in the same way as clrscr() of conio.h. The only way is ncurses if you want all features of dos.h/conio.h/etc windows stuff, and its a lot more powerful than that. You might just love it, why not give the link's tutorial a try? I liked it!
#11 (permalink) |
I guess you want some kind of unified solution so that your program works fine whether compiling in Windows or Linux. For that you'll have to do the one time dirty task of creating the "unified versions" of these functions in one of your custom header file. use #ifdef construct to comment out sections of your code that are irrelevent while running on a particular OS. Best way to create these unified version is to use ncurses for linux/unix and conio.h for windows.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| A) Calling function | rose tamang | Programming | 4 | 15-07-2008 01:20 PM |
| About C functions clrscr, delay. Cannot be found? | aditya.shevade | QnA (read only) | 6 | 25-01-2007 09:45 PM |
| incorrect MS-DOS function?? | rounit | Software Q&A | 9 | 12-01-2007 11:52 PM |
| PC function | citizen | Software Q&A | 5 | 09-12-2006 11:55 PM |
| PHP mail function | anilsmart | Internet & WWW | 11 | 29-10-2004 07:12 AM |
