| Forum |
#1 (permalink) |
Resistance is Futile.
Now the here it gets weirder 1. On issuing startx I get auto-logged in, even though I have auto-login disabled (I *did* have it enabled previously, afterwards I've disabled it) 2. The DE to which I get booted into is random - sometimes its KDE4.1, sometimes its KDE 3.5.9, sometimes its Gnome, although I didn't choose to install KDE 3.5.9 OR Gnome, prolly got isntalled because of some dependencies ? :-/ I have no idea. 3. Even on the rare occasions that I do get a KDE4.1 bootup, I plasma crashes with a sigsev I tried removing .kde and .kde4 directories in /home but makes no difference Any suggestions on (1) How to get the GUI without having to issue startx? (2) Ensuring that KDE 4.1 is what starts up ? EDIT: Seems like KDE4.1 is starting, plasma doesn't load, when I issue plasma & at terminal, plasma gets loaded with widgets, ie, with the second Application launch bar and all: here's a pic Upon checking kdm.log seems kdmgreet is crashing, here's /var/log/kdm.log Code:
This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at http://bugs.freedesktop.org/.
Select the "xorg" product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation git repository.
See http://wiki.x.org/wiki/GitPage for git access instructions.
X.Org X Server 1.4.0.90
Release Date: 5 September 2007
X Protocol Version 11, Revision 0
Build Operating System: openSUSE SUSE LINUX
Current Operating System: Linux sathya 2.6.25.5-1.1-pae #1 SMP 2008-06-07 01:55:22 +0200 i686
Build Date: 07 June 2008 12:37:27AM
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Aug 22 11:02:30 2008
(==) Using config file: "/etc/X11/xorg.conf"
(II) Module "ramdac" already built-in
Synaptics DeviceInit called
SynapticsCtrl called.
Synaptics DeviceOn called
Could not init font path element /usr/share/fonts/TTF/, removing from list!
Could not init font path element /usr/share/fonts/OTF, removing from list!
Driver not XRANDR 1.2 capable, ignoring DISPLAYMANAGER_RANDR_MODE_* settings
KCrash: Application 'kdmgreet' crashing...
Synaptics DeviceOff called
Super User ♦ Moderator | About me Gadgets: HP Envy 14 | Google Cr-48 | D-Link DGL 4500 | Denon AH-C360 | Fiio E5 | iPhone 3GS | Dell U2312HM |
#2 (permalink) |
The Thread Killer >:)
Sorry, not much help from my side, but I wanted to say that it's a BEAUTIFUL wally
Want to make this world a better place? Then, start seeding and don't be just a leecher |
#4 (permalink) |
@phreakout Ah Thanks, It comes with KDE 4.1
@Qwerty Will try it.
#5 (permalink) |
Commander in Chief
What's the result? I have no KDE-3.5.x libs installed (Just GTK2 and KDE-4.x/9999 libs), so I can't exactly figure out what might be causing both of them to run, crash and burn...
Also, check out the other .<file|folder>s on the $HOME and remove anything unnecessary/might belong to KDE3. My .kde/ is ln'd to .kde4/, though I have a .kde3.5 too (Think it came with a previous merge, haven't deleted it though), its not the active one. Could you try changing the link and see as well? Maybe KDE4 is reading it all wrong?
Harsh J www.harshj.com |
#8 (permalink) |
yup, and I've upgraded to KDE 4.1.1 using the 1-click install
@Qwerty havent done it yet, since a reinstall of kdm related packages means that I'll have to d/l from the net and my data card doesnt work in Linux. (I'd done the upgrade using BSNL BB conn, when I was back home on vacation). Will be trying it soon as I switch to Plug2Surf, which might be this weekend. And the only "k" related . files were .kde and .kde4 deleting both had no effect. Will see if changing the link will have any effect.
#9 (permalink) | |
Hey there. Well good news is that I've fixed the kdm_greet crashing issue, while going through the startup logs in YaST(God bless it!!) I found this particular entry
kdm_greet crashes with code 125 signal 0 Quote:
One problem still remaims - it's booting into KDE 3.5.9 instead of KDE 4.1! I had a look at /etc/X11R6/xinit/xinitrc.common which calls the startkde script The startkde script loads KDE4.1 So any pointers on how to get KDE 4.1 starting ? EDIT: .kde is not linked to .kde4
Super User ♦ Moderator | About me Gadgets: HP Envy 14 | Google Cr-48 | D-Link DGL 4500 | Denon AH-C360 | Fiio E5 | iPhone 3GS | Dell U2312HM Last edited by coolpcguy; 27-08-2008 at 10:43 PM. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| starting | vipulgupta | Technology News | 1 | 18-05-2008 10:18 AM |
| Dual boot Linux - boot failure after XP Encryption | patkim | Software Q&A | 1 | 23-03-2008 11:00 AM |
| How to boot in xp in safe mode (Vista + XP Dual Boot) | CadCrazy | Software Q&A | 6 | 14-08-2007 11:43 AM |
| How to Convert any Boot Floppy to Boot CD | VexByte | Software Q&A | 4 | 12-05-2007 06:32 AM |
| XP not starting!!! | kato | Software Q&A | 21 | 11-10-2005 05:54 PM |
