Old 20-08-2008, 09:17 AM   #1 (permalink)
sganesh's Avatar
Default How to start writing GNOME/KDE application
Hi
I am interested in Developing /writing GNOME/KDE Application thro GNU softwares, ,i found Anjuta IDE found to be more applicable for dveloping GNOME application,but i found its much difficult to start with,PL help me in giving link for some sample programs?Pl share us your LINUX devlopment?How to start?
Any ideas or suggestion?Is there any tutorial for such?
Thanks in advance!
sganesh is offline
Old 20-08-2008, 09:22 AM   #2 (permalink)
Think Zen.
ray|raven's Avatar
Default Re: How to start writing GNOME/KDE application
Choose a language and a toolkit to work with.
KDE uses Qt, while Gnome/Xfce use GTK+.
Both toolkits have a wide range of language bindings.
http://www.gtk.org/language-bindings.html
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 20-08-2008, 09:24 AM   #3 (permalink)
Proud to be Linux
abhinandh's Avatar
if you are talking about GUI programming u need to learn GTK or Qt
if u know only C the GTK cos QT got no bindings for C afaik.
if u know some others like python,c++ IMO Qt is better.
http://abhinandh.com
abhinandh is offline
Old 20-08-2008, 09:29 AM   #4 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Simple.
Glade Interface Designer for +designing+ gnome apps.+
+QT4 designer a+nd KDevelop for kde apps.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 20-08-2008, 10:57 AM   #5 (permalink)
sganesh's Avatar
Originally Posted by MetalheadGautham View Post
Simple.
For Glad wat programming stuffs i need to learn!!!
i know c,c++ and java!!!
sganesh is offline
Old 20-08-2008, 11:01 AM   #6 (permalink)
Think Zen.
ray|raven's Avatar
^Glade is an interface designer, it lets you create GTK+ UI's that can then be deployed using C/C++/Java or whatever.
Old 20-08-2008, 11:14 AM   #7 (permalink)
The Smaller Bang
Cool. Glade can be programmed with in C++, C and Java too. Choose one and start designing.
QT4 is used MAINLY with C++, then with Java (qt4-jambi) and then with Python (PyQt).
Old 20-08-2008, 11:15 AM   #8 (permalink)
sganesh's Avatar
Thanks,But in net i found many Ebooks onGNome GUI programming only at cost!!
But i need free tutorials,resources or ebook which guides me in programming,i am unable to find it!!!
pl Help!
sganesh is offline
Old 20-08-2008, 11:26 AM   #9 (permalink)
The Smaller Bang
pl Help!
WTH ? There are LOTS of free ebooks available. Go and check glade's own website.
And see gnome doccumentation.
These interface designers help you place widgets on windows. Then they generate source code.
For a shortcut, with old fashioned text coding, use gtkmm.h headder file in C++. You can use its objects in your program as you like.
Old 20-08-2008, 11:30 AM   #10 (permalink)
OSS Enthusiast!
nitish_mythology's Avatar
If we r familiar with swings in java...do we need to learn gtk fr dev gnome applications?
Do you know, Shinigamis only eat apples???
nitish_mythology is offline
Old 20-08-2008, 11:32 AM   #11 (permalink)
Think Zen.
ray|raven's Avatar
^Yes, you would have to learn gtk , there is java-gnome project that offers an api for java.
You could also learn swt -Standard Widget Toolkit for java, which draws native widgets , unlike swing which tries to emulate the look-and-feel.
Old 20-08-2008, 11:42 AM   #12 (permalink)
OSS Enthusiast!
^^but why?? dont u have a platform independent VM ?? Why wont swings work in Linux???
Ps: Coding in java will be independent of kde/gnome ?? wont it be??
Old 20-08-2008, 11:48 AM   #13 (permalink)
Think Zen.
ray|raven's Avatar
SWT is platform independent.
If you code with gtk , you will need gtk installed for the app to run.
Swing will work in linux, But the UI emulates the gtk look.
However , its getting quite close to the real thing.
Old 20-08-2008, 11:52 AM   #14 (permalink)
OSS Enthusiast!
So we will have the speed advantage if using gtk??
Old 20-08-2008, 11:57 AM   #15 (permalink)
Think Zen.
ray|raven's Avatar
Yes, because the widget drawing is not handled by jvm.
However , the same is the case with SWT.
Old 20-08-2008, 11:59 AM   #16 (permalink)
The Smaller Bang
doubt it. but personally speaking, I think its better to stick to native java instead of a gtk skin for java.
and gtk itself is in C. gtk-java is just a way to use gtk widgets and program with them in java.
And if you need something more professional that blends with gtk, why don't you try wxWidgets ?
Old 20-08-2008, 12:03 PM   #17 (permalink)
OSS Enthusiast!
How do u practically implement java+gtk code together??
Old 20-08-2008, 12:04 PM   #18 (permalink)
Think Zen.
ray|raven's Avatar
@Metal
SWT is a waay better way of getting a native ui using java than using wxwidgets.
@nitish
Java Gnome provides the api of using gtk widgets through java.
http://java-gnome.sourceforge.net/
Old 20-08-2008, 12:09 PM   #19 (permalink)
OSS Enthusiast!
Anyways m better off wth swings..
@Rayraven
Teacher teaching history of comp n binary system
Old 20-08-2008, 12:11 PM   #20 (permalink)
The Smaller Bang
Originally Posted by ray|raven View Post
@Metal
i din day using java. i said wx is the best gtk toolkit.+
Old 20-08-2008, 12:13 PM   #21 (permalink)
Think Zen.
ray|raven's Avatar
You seriously need a new keyboard.
wx is the best gtk toolkit?
Either your nuts or you're drunk.
Old 20-08-2008, 12:21 PM   #22 (permalink)
The Smaller Bang
i used wx and the thing i liked was its ease of use.
never tried py-gtk or gnome-java though.
But TO HELL with gtk. QT pwns 'em all
Old 20-08-2008, 12:24 PM   #23 (permalink)
Think Zen.
ray|raven's Avatar
^You didnt get the point yet.
wxwidgets and gtk are two seperate ui toolkits.
Old 20-08-2008, 04:04 PM   #24 (permalink)
The Smaller Bang
wx is BASED on gtk.
and you can use wx to make native looking apps for gnome and xfce.
vlc is an example.
Old 20-08-2008, 04:11 PM   #25 (permalink)
sganesh's Avatar
How about Anjuta IDE to start with(It comes bundled with OpenSuse11),i saw using that we can Develop KDE/GNOME application?
Have anyone tried?
sganesh is offline
Old 20-08-2008, 04:14 PM   #26 (permalink)
Think Zen.
ray|raven's Avatar
@MetalHeadGautham.
How abt you backup your extraordinary claims for once?
wxwidgets are NOT based on GTK+.
wxwidgets , like SWT , provide a layer to use the native widgets of the platform.
Old 20-08-2008, 04:34 PM   #27 (permalink)
18 Till I Die............
Have anyone tried?
Yes, you can start but you will have to learn one of the GUI toolkits to get any further.
http://www.bash.org/?258908
mehulved is offline
Old 21-08-2008, 04:48 PM   #28 (permalink)
The Smaller Bang
@MetalHeadGautham.
maybe my basic concepts are wrong, but...
till today I thought libwx was an extention to libgtk
Old 23-08-2008, 03:46 PM   #29 (permalink)
GaurishSharma.com
gary4gar's Avatar
I tried glade once, and i was disappointed
in my view its still not upto the mark, though it does work pretty well
gary4gar is offline
Old 24-08-2008, 07:09 AM   #30 (permalink)
sganesh's Avatar
ya,GLade IDE is diificult to follow!!,and It's very tedious to see documentation and start programming!!
sganesh is offline
Gnome doesn't start ilugd Open Source 7 24-09-2007 10:11 PM
How to keep name instead of START in start menu Batistabomb Software Q&A 12 08-03-2007 08:32 PM
Start menu registry hacks to make ur start menu more bautiful and comfortable Siddharth Maheshwari Tutorials 9 22-01-2007 07:01 PM
Hell Lot of Time 2 Start Application(s) blackpearl75 Software Q&A 8 09-11-2006 08:52 PM
Help me pls.. Application doesnt start after double clicking abhi99_iitg Software Q&A 3 23-09-2006 04:53 PM
