Old 08-08-2008, 11:44 PM   #1 (permalink)
Default Help in Fedora
hello friends, i have problem in Fedora 9. I installed but after installation is completed successfully, when i tried to mount partition in my user it doesn't get mounted. It first asked for authorization and after it nothing happens. But in root user it is mounting all my ntfs partition. When i restart computer and log in as root then it mounts partition, after it when i logon to my user then it mounts partition suucessfully. I have tried creating other account and even reinstalling fedora but it doen't work. Please tell me how can i mount partition from my own account.
abhijangda is offline
Old 09-08-2008, 12:23 AM   #2 (permalink)
Default Re: Help in Fedora
In terminal type su
>enter ur root passwd
>enter command mkdir /media/sda1(replace this with the u wld like for ur partition)
>enter command mount /dev/sda1 /media/sda1
This wld mount ur partition sda1 which mostly is the c drive
if u want to mount partitions at boot time edit the file /etc/rc.local
and add the mount commands at the end of the file one after the other
U will have to enter these commands for all the different partitions u want to mount
make sure u make directories for all the drive before u mount them or add the commands in rc.local
U can also add the entries in fstab but fedora's fstab seems to be messy for me atleast
If u get some kind of errors post them
silent008 is offline
Old 11-08-2008, 02:52 PM   #3 (permalink)
thank you silent008. Now Fedora 9 is my favourite linux distro.
Old 11-08-2008, 03:50 PM   #4 (permalink)
Juke Box Hero
Er what?! It automounts all my partitions here. And I recommend against manual mounting through rc.local. That is the job of fstab. You should make the entries there. Messy? Not at all.
Hitboxx is offline
Fedora goes next gen! Fedora 8 Test 1 Released Dark Star Open Source 24 10-08-2007 11:39 AM
Fedora ? TheMaskEditor Open Source 2 11-07-2007 10:18 PM
No more "Fedora Core" but Fedora praka123 Open Source 8 15-01-2007 10:57 AM
Fedora cannot run. rajas700 Open Source 9 27-08-2005 05:05 PM
Fedora: DVD to CDs hitesh_hg Open Source 52 17-12-2004 10:51 AM
