| Forum |
#1 (permalink) | |
Married!
I connect twith pppoe-start and and did ifconfig and found ppp0 connected. But i am not able to open any site (used firefox & konqueror). So i thought may Kmyfirewall is blocking me so i uninstalled it SO i came back to Arch setup and used pppoe-setup and everything was fine. I read Gentoo Network wiki and all stuff but it just doent work, though it connects as shown by o/p of ifconfig below Quote:
I can ping my router (utstar200R) Plz help
topdocumentaryfilms.com Last edited by Rahim; 09-08-2008 at 10:47 AM. |
#2 (permalink) |
18 Till I Die............
Check iptables rules
iptables -L Code:
rc-config delete <servicename> default
http://www.bash.org/?258908 |
#3 (permalink) | |
Married!
This is my iptables -L o/p
What is the purpose of the removing the service and what service to remove?? Will that revert iptables service to default?
topdocumentaryfilms.com |
#4 (permalink) |
There are no iptables rules. It's not a firewall problem then. Start looking towards your network setup.
#5 (permalink) | ||
Married!
I was fiddling in the Live Mode and used this as PPP configuration
But when i used the same procedure in the actual installed-system, it did the same tantrums. Getting connected but no luck with surfing .The light on my modem blinks as if data is passing through but....
#6 (permalink) |
You either configure to use ppp or dhcp, not both.
Can you explain how you configure your connection in other distros? Also check route Code:
route -n
#8 (permalink) |
Married!
Well i used pppoe-setup in my Arch Linux box, so i tried that in Sabayon and then did the Modular Networking way as described in Gentoo Wiki and it did work ONCE in Live Mode but thats it.
@mehulved: So what changes should i do in those files??
topdocumentaryfilms.com Last edited by Rahim; 09-08-2008 at 09:06 PM. |
#9 (permalink) |
remove the last couple of lines related to eth0, it shouldn't be configured.
Maybe you haven't added ppp0 in the list of network interfaces to be started at boot up?
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How To Setup BSNL Dataone in OpenSuse 11.0? | Rahim | Open Source | 2 | 19-09-2008 12:12 PM |
| How to setup your neighbors or friends modem from your home. (Bsnl dataone) | tharun518 | Chit-Chat | 1 | 16-05-2007 10:14 AM |
| Wifi setup on Dataone Type IV modem | Rollercoaster | Software Q&A | 3 | 16-05-2006 07:39 PM |
| How to setup DataOne access in SuSE 9.2 Professional? | sourav123 | Open Source | 15 | 29-12-2005 06:31 AM |
| Dataone Broadband : want to setup login & password. How..? | tkprakash | Broadband and DTH | 3 | 03-10-2005 07:42 PM |
