Old 06-08-2008, 01:03 AM   #1 (permalink)
A human, I use Ubuntu
pradeepbp's Avatar
Default Banshee not working
I installed banshee 1.2 but the application does not start from the menu . it shows 'Starting banshee.....' once I click on the link in the menu, but never actually starts. Older version (0.3) of banshee works fine on my machine.
Any suggestions
pradeepbp is offline
Old 06-08-2008, 03:10 AM   #2 (permalink)
18 Till I Die............
Default Re: Banshee not working
Try starting it from command line i.e. terminal. And post the errors.
http://www.bash.org/?258908
mehulved is offline
Old 06-08-2008, 06:11 AM   #3 (permalink)
pradeepbp's Avatar
It says banshee is not installed. And when I try to install it using apt-get it is fetching only the old version of banshee. But I want the latest version, 1.2.
Old 06-08-2008, 07:48 AM   #4 (permalink)
Linux User
ghost at rest's Avatar
Which version of Ubuntu are you using?
ghost at rest is offline
Old 06-08-2008, 08:06 AM   #5 (permalink)
How did you install it and where?
mehulved is offline
Old 06-08-2008, 09:35 AM   #6 (permalink)
Married!
Rahim's Avatar
Add the following repo in /etc/apt/sources.list and do an update and install the latest Banshee, i assume you are using hardy
deb http://ppa.launchpad.net/banshee-team/ubuntu hardy main
Also it might be good to delete .banshee folder from your home folder (i dont remember it might be in .gnome folder, just check it)
EDIT: Start BAnshee with banshee-1 from the terminal and use this How-To
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 06-08-2008, 11:16 PM   #7 (permalink)
pradeepbp's Avatar
SOLVED !!! Thanks
Old 07-08-2008, 09:45 AM   #8 (permalink)
Married!
Rahim's Avatar
^^^How????
Rahim is offline
Why Banshee need Mono to be installed ? Faun Open Source 34 11-07-2008 04:28 AM
Rock out on Linux with the Banshee 1.0 beta 2 media player Cyrus_the_virus Technology News 15 28-05-2008 09:20 AM
internet not working on vista but working on xp kanz Software Q&A 4 15-04-2008 05:28 PM
** Working/Not-Working Programs with VISTA ** PrinceHeart Software Q&A 42 01-10-2006 04:01 PM
DVD-ROM AND CD-ROM NOT WORKING VERY OFTEN kumarn_2004 QnA (read only) 1 18-04-2005 02:26 AM
