Old 01-08-2008, 05:44 PM   #1 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Unhappy Should I migrate from Arch due to low repository speeds ?
I have been using arch linux for some time now and I find it to be one of the best distros ever. Its very simple and easy to use, and configuring is very easy since only a handful of text files need to be edited. KDEmod simply rocks.
But I have one major issue with it - its repositories are simply too slow. I am not able to download anything at all during the night time UL BSNL H500 broadband surfing from the repos, since I get sick speeds like 15kbps. But at noon and evening, I get blazing fast download speeds, which are useless since I can't use that time for downloading anything. Rankmirrors script revealed that the fastest mirror I can access is also just 16kbps in speed right now. I don't know what to do now. Can anyone help and/or advice me here ?
Is there any hack for pacman to make it download files in paralell, i.e, many files at a time ? Or can I somehow make wget, which pacman uses, to accelerate downloads ?
I really don't want to leave arch and KDEmod, but I think I am being forced to, by slow speeds. I am considering going for CentOS 5.2, whose DVD I am downloading from internode.net. What do you guys say ? What will be the speed difference between CentOS and arch ? What about the new debian testing release ?
Apple iPad 2 16GB WiFi
MetalheadGautham is online now
Old 01-08-2008, 05:52 PM   #2 (permalink)
Pat
Member of Apple Family
Pat's Avatar
Default Re: Should I migrate from Arch due to low repository speeds ?
pacman does not use wget by default. And yes, you can use a download accelerator of your choice with pacman (axel for example)
Pat is offline
Old 01-08-2008, 05:56 PM   #3 (permalink)
The Smaller Bang
tell me how
Old 01-08-2008, 06:01 PM   #4 (permalink)
Pat
Pat's Avatar
Please see your pacman.conf. IIRC, they have given a few examples as comments in that file.
Pat is offline
Old 01-08-2008, 06:29 PM   #5 (permalink)
The Smaller Bang
Tell me a commandline download accelerator that is reliable. Quick.
Old 01-08-2008, 06:34 PM   #6 (permalink)
Pat
Pat's Avatar
Yes sir. Your order is my command
Try axel (as already mentioned in previous post) or prozilla.
Also try out curl as mentioned in the following blog article. It will be useful especially when downloading large files like, for example, distro isos.
http://linuxhelp.blogspot.com/2007/0...for-linux.html
Read the section: Using Curl to speed up your downloads
Pat is offline
Old 01-08-2008, 06:46 PM   #7 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Take a PowerPill
FilledVoid is offline
Old 01-08-2008, 06:51 PM   #8 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Exclamation Re: Should I migrate from Arch due to low repository speeds ?
^^^Thats why I had to ditch Arch and switch over to slower Ubuntu 8.04.1 again.
I think BSNL is slowing down the speed sometimes in the night unlimited hours since I saw some other users in the vicinity were getting good speeds over the same mirror using Airtel. Can someone confirm it ?
debsuvra is offline
Old 01-08-2008, 06:59 PM   #9 (permalink)
FilledVoid's Avatar
I get awesome speeds to the morning and about upto 50-80 kbps in the regular times. I usually schedule updates at 7:00 am -8:00 and have my system shutdown at 7:55 .
Old 01-08-2008, 07:05 PM   #10 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Are u using Home 500 man ? If yes, then u call 50-80 kbps awesome ? Arch repos give at least 180-200 kbps in other times of the day but in that hourspan, it's horrible. I also experienced the slightly better speeds from 7 to 8 AM but that is not close enough to the speed we should have.
debsuvra is offline
Old 01-08-2008, 07:20 PM   #11 (permalink)
FilledVoid's Avatar
Yes I'm using Home 500. Yes I call it Awesome because of couple of things.
1. Arch doesn't have a server anywhere close to us.
2. If you notice the time difference theres going to be more traffic in the night than the morning.
3. On Ubuntu the download speeds were so pathetic from IIT that I started downloading updates from Mongolia.
You might find it horrible but I find it suitable for my needs.
Old 01-08-2008, 07:46 PM   #12 (permalink)
OSS Enthusiast!
nitish_mythology's Avatar
Join the bright forces, get 'Zenwalk'....
Hope its not sounding like an advertisement
Do you know, Shinigamis only eat apples???
nitish_mythology is offline
Old 01-08-2008, 08:16 PM   #13 (permalink)
4T7
4T7's Avatar
Join the brightest forces, get Slackware
4T7 is offline
Old 01-08-2008, 08:35 PM   #14 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
But I got some 180-200 kbps speed from arch Australia servers, so why 50-80 would be amazing ?
On the other hand, Taiwanese ubuntu servers are the best I've seen in many days for Ubuntu. I presume praka can also confirm it. The IIT-M repo simply sucks.
No it is not an advertisement.
Now it starts looking like an advertisement.
debsuvra is offline
Old 01-08-2008, 08:53 PM   #15 (permalink)
The Smaller Bang
/me heard lots about curl and even used it in firefox via flashgot extention.
I heard its wget's arch rival. is it really that good ?
Old 01-08-2008, 09:05 PM   #16 (permalink)
FilledVoid's Avatar
I was mentioning that I get 50-80 in most times regardless of where or when. Hence its great for me. I also get good speeds in the times mentioned above by OP. I believe I did a 8 MB update today and the average at the end was about 192 kbps but this was at 8:00 am I believe.
Anyway Ive had the best experience with Pacman then with Ubuntus update system. I don't see myself changing anytime soon.
Old 01-08-2008, 09:11 PM   #17 (permalink)
The Smaller Bang
offtopic: kdemod4 is sooooo damn fast and sexy but where is kde control center ?
Old 01-08-2008, 09:22 PM   #18 (permalink)
18 Till I Die............
Join the bright forces, get FreeBSD.
http://www.bash.org/?258908
mehulved is offline
Old 01-08-2008, 09:37 PM   #19 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
hey there are KDEmod4 available ????
Why didn't you tell us ??? I am dying to try it since KDE4.1 has blown my mind in Ubuntu.
debsuvra is offline
Old 01-08-2008, 10:01 PM   #20 (permalink)
4T7
4T7's Avatar
Already have it
4T7 is offline
Old 01-08-2008, 10:32 PM   #21 (permalink)
Filled-Void already did that in another thread. I have been using KDEmod 4.1 since then. The only reason I am using arch.
mehulved is offline
Old 01-08-2008, 10:34 PM   #22 (permalink)
migration...ahem...ahem !
Faun is offline
Old 01-08-2008, 11:04 PM   #23 (permalink)
Pee into the Wind...
shady_inc's Avatar
In what way is it better than KDE 4.1.?
Life is as complicated as you say it is.
shady_inc is offline
Old 01-08-2008, 11:24 PM   #24 (permalink)
Commander in Chief
QwertyManiac's Avatar
KControlCenter is now System Settings (systemsettings)
Harsh J
www.harshj.com
QwertyManiac is offline
Old 02-08-2008, 07:14 AM   #25 (permalink)
The Smaller Bang
System Settings sucks. I wonder why they brought in that ugly app from Kubuntu.
I really miss KControlCenter.
And how can I switch to root mode for certain operations ?
Old 02-08-2008, 05:06 PM   #26 (permalink)
Console Junkie
aditya.shevade's Avatar
LOLOLOL... Use Pacific.au mirror.... It is fast.
--- Console Junkie
aditya.shevade is offline
Old 02-08-2008, 05:19 PM   #27 (permalink)
For me, http://mir.archlinux.fr is the fastest. Maybe it's cause I am on a different ISP.
mehulved is offline
Old 02-08-2008, 10:02 PM   #28 (permalink)
The Smaller Bang
I will find out the truth tonight.
Tonight is the night for some hectic downloading. I need to get CentOS 5.2 DVD ISO for testing purposes on my extra partition.
Along with that, I will download lots of software via pacman.
Old 03-08-2008, 02:17 AM   #29 (permalink)
FilledVoid's Avatar
Did any of you actually try Powerpill?
Old 03-08-2008, 04:19 AM   #30 (permalink)
GaurishSharma.com
gary4gar's Avatar
Yep, its fastest of the whole lot, but still not upto the mark. i get around 60kBps.
anyways, now i have a fully set up machine to i don't need to download much.
i am on KDE3.xx and if upgrade to KDE4.1. how much i have to download?
gary4gar is offline
Installing Arch Linux SunnyChahal Open Source 35 18-12-2008 08:57 PM
Arch Linux Help needed ! Dark Star Open Source 1 31-01-2008 08:53 PM
BTech or B.Arch??? deepak.krishnan Chit-Chat 3 04-06-2007 03:14 PM
airtel, slow download speeds and gr8 ul speeds. legolas Broadband and DTH 6 26-08-2005 07:47 PM
Acronis Migrate Easy v7.0.619 Curious Guest QnA (read only) 3 04-05-2005 08:30 PM
- by gforz
- by soumya
