Old 31-07-2008, 06:12 PM   #1 (permalink)
I M A *STAR*
saqib_khan's Avatar
Default Can't mount NTFS drive in ubuntu, Y ?
Hi,
My friend has Win XP + Hardy Heron. Dual booting. I installed Ubuntu in his PC. From that time till now, i can't open any NTFS drive in Ubuntu. I mean y r the drives not mounting, what's the problem??
Win XP is working fine. And Win XP is also shut down properly.
So guys, any suggestions?
Blogging at:
Technostarry
saqib_khan is offline
Old 31-07-2008, 06:33 PM   #2 (permalink)
Default Re: Can't mount NTFS drive in ubuntu, Y ?
u should have used FORCE to check
Faun is offline
Old 31-07-2008, 06:35 PM   #3 (permalink)
I M A *STAR*
saqib_khan's Avatar
And how to do this??
Blogging at:
Technostarry
Old 31-07-2008, 07:26 PM   #4 (permalink)
Linux User
ghost at rest's Avatar
Open Terminal and execute this
sudo fdisk -l
* Its small L in fdisk -l.
Note down device name assigned to NTFS partition(s).
Let say, /dev/sda1 is NTFS partition. Execute this
sudo mkdir /media/sda1
sudo mount -t ntfs-3g /dev/sda1 /media/sda1 -o defaults,umask=0
ls /media/sda1
In case any of above command throws error, post exact error message here.
You can edit /etc/fstab file to automount partition(s) at boot up.
ghost at rest is offline
Old 31-07-2008, 07:35 PM   #5 (permalink)
Married!
Rahim's Avatar
Have you installed ntfs-config?
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 31-07-2008, 07:42 PM   #6 (permalink)
I M A *STAR*
saqib_khan's Avatar
@rahimveron
No
Blogging at:
Technostarry
Old 31-07-2008, 07:45 PM   #7 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Doesn't ntfs-config get installed by default? I don't recall adding it to get my NTFS drives active in Ubuntu.
FilledVoid is offline
Old 31-07-2008, 08:16 PM   #8 (permalink)
Married!
Rahim's Avatar
^I did install it in Mint 5.0 , so it is based on Hardy so i thought it was not installed in his case.
If it is then he has to use the force way to mount them.
So search for it in Synaptic and install it and activate it from System Tools-->NTFS COnfiguration Tool and enable write support for internal/external drives.
Rahim is offline
Old 31-07-2008, 09:08 PM   #9 (permalink)
Linux User
Execute this
sudo apt-get update
sudo apt-get install ntfs-config
Old 31-07-2008, 11:14 PM   #10 (permalink)
24X7 GNU/Linux UseR
i think fuse needs to be integrated with kernel
try $sudo apt-get install fuse fuse-ntfs-3g dkms dkms-fuse
nach is offline
Old 31-07-2008, 11:50 PM   #11 (permalink)
Linux User
There is no need to install any other package except ntfs-config. All other packages are pre-installed in Ubuntu Hardy Heron.
Old 01-08-2008, 12:01 AM   #12 (permalink)
ntfs-3g is comes by default in Ubuntu 8.04
yeah but you do need to install configuration GUI, only if you are a click click geek
Faun is offline
Old 01-08-2008, 11:48 AM   #13 (permalink)
I M A *STAR*
saqib_khan's Avatar
Ok, thank u all.
The problem solved automatically, i have'nt done anything.
Computer is an error machine, sometimes prob solves automatically & sometimes not.
Blogging at:
Technostarry
How to mount NTFS partition in Ubuntu DeSmOnD dAvId Open Source 53 24-08-2007 01:54 AM
How to mount NTFS on Feisty? Dark Star Open Source 21 17-06-2007 09:55 AM
Unable to mount NTFS Partitions sachin_kothari Open Source 15 19-05-2007 07:45 PM
Mount NTFS in Ubuntu nishant_nms Open Source 4 07-12-2005 02:46 PM
Unable to mount all ntfs drives in fedora3.mount one ntfs, neerajvohra Open Source 1 06-02-2005 03:56 PM
- by gforz
- by soumya
