Old 27-07-2008, 08:39 AM   #1 (permalink)
OSS Enthusiast!
nitish_mythology's Avatar
Question Panel Disappearing in Zenwalk.
Yestarday after a power cut at my place, I turned off my lappy and booted into my Zenwalk installation (Xfce) after an hour or so.
I was surprised to see the panel n dock disappearing.. Tried to crearte a new panel, by going
Right Click ----- Settings ---- Panel Manager
Tried to open panel manager from Zenwalk settings.
It refused to work!!
I was clicking on the panel manager and there was no action ! In the end I had to create a new login id n I got my panels back. All is working well here and I can acces panel settings.
What was the reason behind the strange behaviour??
Do you know, Shinigamis only eat apples???
nitish_mythology is offline
Old 27-07-2008, 10:03 AM   #2 (permalink)
mastana
Posts: n/a
Default Re: Panel Disappearing in Zenwalk.
your filesystem may got corrupted due to direct failure.try to use a livecd and run "fsck.ext3 -fvy /dev/sdxy" where sdxy is your zenwalk partition.make sure the partition NOT mounted.
Old 27-07-2008, 10:54 AM   #3 (permalink)
Linux User
ghost at rest's Avatar
It looks like config files of Xfce have been corrupted. Are there any .xfce-xx folders in your home folder? Rename those and log out/in back.
ls -al
ghost at rest is offline
Old 27-07-2008, 11:57 AM   #4 (permalink)
OSS Enthusiast!
I have deleted the User Id..
Cant do much.. Nyways how can those files get corrupt all on their own?
Old 27-07-2008, 04:54 PM   #5 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
Array your question have answer itself.. Improper Shutdown.. Thats why the config. files got corrupted.
A disk check (and renaming old config file) and restarting of PC will solve the problem in most cases.
Quiz_Master is offline
Old 27-07-2008, 05:54 PM   #6 (permalink)
OSS Enthusiast!
^^ There was no improper shutdown.
I was working on my lappy.
Old 31-07-2008, 10:03 AM   #7 (permalink)
OSS Enthusiast!
Found the Reason
Its a bug that exists and is causing the problem! All I need to do was pess alt+f2 n type xfce4-panel.
Thats it, work done!
Zenwalk 5.2 is ready ! praka123 Open Source 3 08-06-2008 05:42 PM
Zenwalk 5.2 released ! MetalheadGautham Open Source 3 08-06-2008 05:14 PM
Zenwalk 5.0 is not an option; MEPIS 7.0 is not a keeper...and GPL is the reason! praka123 Open Source 16 14-03-2008 11:17 AM
ZenWalk Linux LILO COnfig. ray|raven Open Source 5 21-09-2006 05:51 PM
disappearing red stan QnA (read only) 11 06-10-2004 12:37 AM
- by gforz
- by soumya
