Old 26-07-2008, 09:55 PM   #1 (permalink)
Err.. what?
BSOD's Avatar
Default Ubuntu Resolution Problems
I have this Nvidia 7600GT video card and a LCD which has native resolution of 1440x900 but, Ubuntu shows a maximum resolution of 800x600 and after installing the Nvidia drivers it got reduced to 640x480.
Guess many guys have already faced this problem before, but, none of the solutions suggested seemed to work for me.
BSOD is offline
Old 27-07-2008, 10:24 AM   #2 (permalink)
mastana
Posts: n/a
Default Re: Ubuntu Resolution Problems
open /etc/X11/xorg.conf of ubuntu as "gksudo gedit /etc/X11/xorg.conf " and add below option in section "Display"
    SubSection     "Display"
       Viewport     0 0
        Depth       24
	FbBpp       32
Modes      "1440x900"
    EndSubSection
Old 27-07-2008, 10:50 AM   #3 (permalink)
Linux User
ghost at rest's Avatar
Hi BSOD !
Which version of Ubuntu are you using? How did you install Nvidia Driver?
ghost at rest is offline
Old 27-07-2008, 06:16 PM   #4 (permalink)
Err.. what?
BSOD's Avatar
I found a working method which is seemingly hidden. If anyone needs it here it is -
Go to Screens and Graphics in Applications Menu - Others (it is not there by default and you may have to add it. Right click on Applications Menu and choose Edit Menu and add it there.)
Choose your model and resolution and other settings. If the monitor is not in the list, just choose Generic and choose the resolution or better still if it works Auto Detect.
@mastana - I had tried that method after googling. It didnot work for me.
I am using Ubuntu 8.04 - the Hardy Heron. For the Nvidia Driver I updated the repository sources and installed the restricted driver.
Thanks for helping.
BSOD is offline
Old 31-07-2008, 03:26 PM   #5 (permalink)
Arrow reply3
Wow! This post rocks
ipodfansmail is offline
Old 31-07-2008, 09:28 PM   #6 (permalink)
Linux User
Default Re: reply3
I am not getting it. You posting same line in a lot of other forums too. It looks like you are creating ground for mass SPAMMING. Your Member ID and post contents points to that only.
Ubuntu resolution problem blademast3r Open Source 9 03-06-2008 07:32 AM
Ubuntu resolution mavihs Open Source 6 15-12-2007 10:37 AM
Wide Screen Resolution Problems vaibhy_28 Hardware Q&A 5 29-10-2007 12:11 AM
display (resolution) problems srinivasaraor Hardware Q&A 1 31-08-2007 06:00 PM
Help me Fix Ubuntu Resolution robin.rawal Open Source 4 08-06-2007 09:12 PM
- by gforz
- by soumya
