Old 23-07-2008, 02:06 PM   #1 (permalink)
I WANT MORE FPS!!
adithyagenius's Avatar
Default surround sound support?
I tried ubuntu 8.04 and fedora 9 and tried some tips from websites to enable 5.1. I was able to use 5.1 on fedora 6 and fedora 7 and year back. But now all linux distro I have used are unable to output 5.1. I also tried installing m2a-vm linux drivers on a system with m2a-vm but it got screwed up.
My configs:
690g and 740g mobos
realtek 883 and 888 ALC
7600gt and 8600gt gfx
rlt 8111 and 8139 ethernets
athlon x2 4000+ and 4800+
I want sound from all 5 speakers and subwoofer when I play songs on amarok or watch videos in mplayer or vlc.
Or please suggest a distro meets the following specs
1. 5.1 support in mplayer, amarok and gparted.
2. less than 7 gb hdd and should support ntfs read/write.
3. supports my hardware and has pppoe-conf or something as easy.
4. Should have gcc and java compiler in the installation or in their repos.
5. compiz is appreciated but not must.
E8500+Asus P5Q Pro, GTX280 OC, 4GB RAM+RAID0 2*WD 500GB, CM690+Corsair 650TX, Razer Diamondback+Goliathus Control Edition Omega, Microsoft Natural Ergonomic 4000, Dell E228WFP, X-Fi Titanium+T6060
adithyagenius is offline
Old 23-07-2008, 02:16 PM   #2 (permalink)
Default Re: surround sound support?
1) Try Mandriva. AFAIK gparted dont need 5.1 support to format a HDD
2) avg size is far less than 7
3) openSUSE, mint or Mandriva
4) every current distro have gcc and java in their repos
5) yeah by defaults its installed in many distros, use debian or arch to make from scratch without any bloat.
Faun is offline
Old 23-07-2008, 02:25 PM   #3 (permalink)
I WANT MORE FPS!!
Dude I need 5.1 support to listen to music, not to foramt hdd. I by mistake put gparted there.
So do you know that 5.1 is going to work with mandriva? I am seeing that all distros are using similiar audio software. All have same interface and all have pulse audio. I think thats the problem. I need the old sound from fedora 7 back. It was not true 5.1 but it atleased utilised all the 5 speakers and most importantly the subwoofer.
Old 23-07-2008, 02:49 PM   #4 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
If you are using Realtek or Intel HDA onboard sound devices then refer to the wiki for install directions for configuring them correctly. I don't use Hardy heron now so I'm not sure if it has been fixed correctly. Also the above link should ahve everythigny ou need to configure it correctly.
FilledVoid is offline
Old 23-07-2008, 05:01 PM   #5 (permalink)
String Phreak
mediator's Avatar
Fedora 9 gave me 5.1 by default! But in some cases u have to enable a switch called "Line in as Output".
mediator is offline
Old 25-07-2008, 05:02 AM   #6 (permalink)
I WANT MORE FPS!!
how to do that?
tried similiar methods suggested in various forums but didnt work.
Last edited by adithyagenius; 25-07-2008 at 05:04 AM. Reason: Automerged Doublepost
Old 25-07-2008, 07:16 AM   #7 (permalink)
FilledVoid's Avatar
This would go much easier if you said What you tried and why it doesn't work. As in error messages or whatever.
Old 25-07-2008, 07:32 AM   #8 (permalink)
Faun is offline
Old 25-07-2008, 01:19 PM   #9 (permalink)
I WANT MORE FPS!!
Originally Posted by T159 View Post
I have headphone switch. No such switch as line in as output and mic as output.
All my mobos are AMD based -690G, 740G. I have confirmed the problem exists on ATI RS400/SB450 for Intel processors. All have Realtek HDA ALC883, ALC888 and ALC888 repectively.
Do ATI and linux hate each other?
Old 25-07-2008, 03:07 PM   #10 (permalink)
String Phreak
mediator's Avatar
Edit > Preferences > Line in as output
Checked there?
mediator is offline
Old 25-07-2008, 05:51 PM   #11 (permalink)
FilledVoid's Avatar
I had the same problem with Realtek. I ended up compiling ALSA with the newer packages. Also I had to edit some options to specify the number of pins I have.
3stack-dig 3-stack (2-channel) with SPDIF
3stack-6ch 3-stack (6-channel)
3stack-6ch-dig 3-stack (6-channel) with SPDIF
6stack-dig 6-stack with SPDIF
lenovo-101e Lenovo laptop
auto auto-config reading BIOS (default)
I selected one of these not sure which one. But whatever I did is specified on my blog which for some odd reason won't open up . Heres a thread I had on LinuxQuestions.org
Getting a surround sound speaker system rohan Audio 3 01-04-2008 12:57 PM
Enabling surround sound with Ubuntu 6.06 baccilus Open Source 4 26-11-2006 11:34 PM
surround sound headphones vikrant1986 Audio 5 15-11-2006 12:56 AM
no surround sound in FC4 prasad_den Software Q&A 2 21-10-2005 06:08 PM
Surround Sound Problem doom_marine QnA (read only) 9 06-09-2005 11:50 PM
- by gforz
- by soumya
