Old 19-07-2008, 07:54 PM   #1 (permalink)
Tech Addict
Default Script for scheduling Dataone connection in Opensuse
Hi,
I'm using OpenSuse 11.0.
I've a Dataone broadband connection in bridged mode. I use Kinternet to manually connect to internet. I've a limited bandwith net connection which provides unlimited downloads between 2.00-8.00AM.
I've tried to keep running my net connection and scheduling downloads in Ktorrent. But when kept idle, the connecion disconnects after sometime. I've entered Idle Time Out as 0 in DSL settings.
Executing sudo -i and /sbin/ifup dsl0 from terminal starts the net.
I've tried making a script as follows and running it using Kcron
#!/bin/bash
sudo -i
/sbin/ifup dsl0
exit 0
I've removed password for sudo by using Yast also made the file executible from the properties.
But this doesn't work.
Now pls tell me why?
______________
Arup
arupch is offline
Old 20-07-2008, 12:01 AM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: Script for scheduling Dataone connection in Opensuse
"sudo -i" is irrelevant. The logic lies in adding to cron a timing from 2-8, that executes the script every minute or 5 minutes whicheva u like. I had made a script for similar purpose. Here's the modified one for ur use.
#!/bin/bash
cd /home/scripts/
ping 208.67.222.222
-c 1 > /dev/null
val=`echo $?`
if [ $val -ne 0 ];then
echo "--> Restarting" >> autostart.log
date >> autostart.log
echo "******************" >> autostart.log
#Command that starts the connection, you can edit this
/sbin/ifup dsl0
fi
1. Save n Name the script say, "nightrider.sh" to a folder say, "/home/scripts" where all ur other scripts are stored.
2. command "chmod +x nightrider.sh" for making it executable
3. For cron u do
*/5 2-8 * * * /home/scripts/nightrider.sh
The IP 208.67.222.222 belongs to opendns. It is only there for checking the internet connection status. "autostart.log" is the log generated that shows "when" the script was executed. I hope it works!
mediator is offline
Old 20-07-2008, 09:52 AM   #3 (permalink)
Tech Addict
Originally Posted by arupch View Post
Hi,
#!/bin/bash
sudo -i
/sbin/ifup dsl0
exit 0
Thank you for your reply.
I'll try that.
But above when saved as a file (dsl.sh) and made executible does not starts net when run from terminal.
whyyy??
___________
Arup
arupch is offline
Old 20-07-2008, 01:18 PM   #4 (permalink)
String Phreak
mediator's Avatar
U must understand then how the shell scripts work. When u put sudo or su, u r simply "entering" a "new shell" which doesn't know about next lines/commands in the script. So it doesn't matter if u have a password for root or not. It is wrong to put "sudo" in a shell script!
U can remove the sudo part i.e "sudo -i" and initiate the script u created as "sudo sh dsl.sh". U can also remove the "exit 0" part as well..
mediator is offline
Old 20-07-2008, 07:12 PM   #5 (permalink)
Tech Addict
Thank you for your help. I'm trying to get this issue solved for several days in different forums - but nobody except you helped.
I tried your script: i saved the file as test.sh in desktop - also changed the path statement in the script.
Then executed ./test.sh
Which gave me:
/sbin/ifup: line 207: /dev/shm/sysconfig/config-dsl0: Permission denied
dsl0
error: can't create pid file, Permission denied
failed to bring interface dsl0 up
awk: cmd. line:1: fatal: cannot open file `/etc/ntp.conf' for reading (Permission denied)
Checking for network time protocol daemon (NTPD): unused
arup@linux-9c3u:~/Desktop> touch: cannot touch `/dev/shm/sysconfig/ready-dsl0': Permission denied
But when I give sudo sh test.sh it works:
dsl0
interface dsl0 is up
So how do I put the Cronjob?
arupch is offline
Old 20-07-2008, 11:00 PM   #6 (permalink)
String Phreak
mediator's Avatar
sudo crontab -e. I hope u know how to use the "vi editor"! Its really simple.
You're Welcome.
mediator is offline
Old 21-07-2008, 08:47 AM   #7 (permalink)
TheSaint
NucleusKore's Avatar
Arupch, it would be nice if you could write a final post detailing the complete instructions and your experience it would be useful for other users, and maybe post the script too.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 21-07-2008, 09:01 AM   #8 (permalink)
left this forum longback
praka123's Avatar
@arupch: ifup and all need root permission. why not run the script as root(risky may be!) ,as cron can only execute those commands as su -.
praka123 is offline
Old 21-07-2008, 10:05 AM   #9 (permalink)
Tech Addict
Well. Thanks Mediator once again.
I've set the Cronjob as guided by you.
I'll write the detailed steps followed by me soon.
Here are the steps that I followed.
All the credits goes to Mediator - I just followed his instructions.
#!/bin/bash
cd /home/scripts/
ping 208.67.222.222 -c 1 > /dev/null
val=`echo $?`
/sbin/ifup dsl0
fi
3. sudo crontab -e.
4. For cron u do */5 2-8 * * * /home/scripts/nightrider.sh
____________
Arup
arupch is offline
Old 24-07-2008, 08:40 PM   #10 (permalink)
TheSaint
Good work
How-to configure a PPPoE Broadband Internet Connection in OpenSuSE 11.0 NucleusKore Tutorials 34 24-07-2009 06:29 AM
How To Setup BSNL Dataone in OpenSuse 11.0? Rahim Open Source 2 19-09-2008 12:12 PM
OpenSuSE 10.3 for standalone PCs without an internet connection NucleusKore Open Source 22 01-01-2008 10:54 PM
scheduling a connection liquid_snake Tutorials 3 26-07-2007 11:01 PM
Dataone usage & PC scheduling webgenius Broadband and DTH 2 08-03-2007 05:57 PM
- by gforz
- by soumya
