Old 18-07-2008, 10:00 AM   #1 (permalink)
A human, I use Ubuntu
pradeepbp's Avatar
Default Ubuntu shutdown issues
I use Ubuntu Hardy.
I am experiencing shutdown problems like taking long time, pc hanging while shutdown etc., recently. I see lot of messages on screen during shutdown, while this was not the case earlier. Earlier I used see only the orange ubuntu progress bar and the shutdown was quick.
The recent changes that I made to the system are:
1. Installed Avant Window Navigator
2. Installed Screenlets
3. Installed Wine.
Could any of these be causing the problem? Any suggestions?
pradeepbp is offline
Old 18-07-2008, 10:16 AM   #2 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Default Re: Ubuntu shutdown issues
Could you post some of the error messages, in case it doesn't scroll past too fast.
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 18-07-2008, 10:33 AM   #3 (permalink)
pradeepbp's Avatar
I wish I could. It really scrolls very fast. Does is get written in a log file, which I can view ?
Old 18-07-2008, 10:34 AM   #4 (permalink)
left this forum longback
praka123's Avatar
some service fails to stop properly .that you should have to check from /var/log/ dir files.
an easy method to see the error ,you may open a terminal and "sudo telinit 1" and see which process is hanging.(press alt+tab to see the o/p).
praka123 is offline
Old 18-07-2008, 11:16 PM   #5 (permalink)
pradeepbp's Avatar
which is the exact log file that I have to check?
Old 19-07-2008, 06:08 AM   #6 (permalink)
Vivek788's Avatar
i too have some error messages..like failed to close some niterface...and ya i can't shutdown with the menu..i have to do alt+ctrl+bkspace.
Clicking shutdown on the menu leads to system hanging..
Viva Green Computing!!
http://www.vivtech.blogspot.com/
Vivek788 is offline
Ubuntu 7.10 shutdown problem cool_techie_tvm Open Source 2 25-11-2007 12:08 PM
Multimedia issues in Ubuntu 7.04 Akshay Open Source 19 22-06-2007 11:42 AM
Ubuntu 6.06 64bit hangs on shutdown ! baccilus Open Source 1 09-12-2006 10:26 AM
Mouse issues on Ubuntu teen Open Source 11 09-06-2006 04:12 PM
Windows SHUTDOWN Problem, system freezez on shutdown screen catch_maxi Software Q&A 2 16-03-2006 07:38 PM
- by gforz
- by soumya
