Old 14-07-2008, 08:17 PM   #1 (permalink)
harshitjain's Avatar
Default No USB Hard Disk!!
I have a usb hard disk, which really is an internal drive with casing. Well the problem is that whenever i connect it to my comp. fedora does nothing, it doesnīt even show an error. i donīt know what to do as most of my music lies in that drive. Please HELP!!
harshitjain is offline
Old 14-07-2008, 08:18 PM   #2 (permalink)
Default Re: No USB Hard Disk!!
Did you try to mount it manually ?
ThinkFree is offline
Old 14-07-2008, 08:40 PM   #3 (permalink)
in search of myself
CadCrazy's Avatar
Check out in places menu in case of Gnome
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
CadCrazy is offline
Old 14-07-2008, 09:04 PM   #4 (permalink)
Married!
Rahim's Avatar
sudo fdisk -l
might help to show the drives
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 15-07-2008, 11:16 AM   #5 (permalink)
iīm using fedora core 9. it says command not found when i type fdisk -l.
Old 15-07-2008, 11:57 AM   #6 (permalink)
Married!
Rahim's Avatar
Use this in Terminal
su
and enter the root password to have root privilege ,then use
fdisk -l
Rahim is offline
Old 15-07-2008, 01:55 PM   #7 (permalink)
^^use
su -
"-" is necessary AFAIK.
Faun is offline
Old 15-07-2008, 02:16 PM   #8 (permalink)
Question Re: No USB Hard Disk!!
ok..... so now i can see my usb drive in the terminal, but how to mount it and make fedora mount it automatically whenever i connect it. Also i still donīt know why the drive is still not shown in the places menu ??
Old 15-07-2008, 06:32 PM   #9 (permalink)
Married!
Rahim's Avatar
Originally Posted by T159 View Post
^^use
su -
nah its not.
You have to edit /etc/fstab file and make an entry for that hard drive
Rahim is offline
Old 15-07-2008, 06:36 PM   #10 (permalink)
k it was on older version so
could anyone confirm ?
Faun is offline
Old 15-07-2008, 06:40 PM   #11 (permalink)
Married!
Rahim's Avatar
What is the Hard Disk's format? ntfs/fat?
Rahim is offline
Old 15-07-2008, 07:10 PM   #12 (permalink)
the usb drive has 4 partitions(as it was formerly an internal drive) and all of them are FAT32.
Old 15-07-2008, 07:19 PM   #13 (permalink)
Married!
Rahim's Avatar
What is the output of fdisk -l and blkid with the drive connected?
Rahim is offline
Old 15-07-2008, 08:02 PM   #14 (permalink)
or use
ls /dev/disk/by-uuid
to get the UUID of the partitions
Faun is offline
Hard thinking about Hard Disk power_8383 QnA (read only) 10 25-03-2008 05:14 PM
all files from IDE hard disk with windows 2000 to SATA II hard disk with windows jagadish2005 Software Q&A 8 10-04-2007 11:08 AM
Hard disk to buy ? sbhas2k Hardware Q&A 4 10-12-2006 12:40 PM
compaq deskpro ep/sb series not detecting hard disk disk aditya169 QnA (read only) 3 22-05-2005 07:14 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
- by soumya
- by gforz
