Old 09-07-2008, 11:50 AM   #1 (permalink)
cooldude666666's Avatar
Lightbulb Unable to use sound device in FreeBSD 7
I have an Acer Aspire 5920 laptop with Realtek HD Audio(At least that is what the software says in windows). I recently installed FreeBSD 7 and after a bit research was finally able to play sound after downloading and installing the Open Sound System(OSS). But, the problem is that no mixers recognize the sound device. When I used the osstest command to test the sound, I heard sound only from /dev/oss/hdaudio0/pcm5 and /dev/oss/hdaudio0/spdout0. In the pcm5 device, the right channel was outputting only noise so I ruled out this device. I chose to use the spdout0 device (which obviously, as its name explains, is the SPDIF-out) as it plays clear sound. I wan kmix to use this device but I don't know how to do it. I have tried to play a complete song using the ossplay program using the spdout0 device. Can anyone tell me how can I make it my default sound device so that I can play audio???
Keeping it Posted!!!!!!!!!
cooldude666666 is offline
Old 11-07-2008, 10:31 AM   #2 (permalink)
18 Till I Die............
Default Re: Unable to use sound device in FreeBSD 7
Check your audio chipset with lspci.
Also check fstat if anything is using the sound device.
http://www.bash.org/?258908
mehulved is offline
Old 14-07-2008, 02:56 PM   #3 (permalink)
Sorry, But I shifted to fedora 9 from this months' digit dvd.
How to connect a usb device which the win xp says as UNKNOWN DEVICE? aQi_g Software Q&A 8 03-07-2008 03:59 PM
fefora 7 - ACPI:Unable to turn cooling device [c1e8bdec] on message comes jaisrigopi Open Source 1 26-09-2007 10:48 PM
Corrupted Sound Device ? nicole2208 QnA (read only) 10 14-06-2006 10:53 AM
FREEBSD digitizen Open Source 9 04-11-2005 01:09 AM
FreeBSD FAQ klinux Open Source 15 22-11-2004 10:32 PM
- by gforz
