Old 29-06-2008, 10:20 AM   #1 (permalink)
Debian Gnu/Linux User
Sathish's Avatar
Angry Help me...On Linux Booting..
i have recently installed mandriva 2008 from ISO Cd..
after i installed necessary updates thr. online, i restarted the system..
after successful booting, the system hangs when the progress bar have (before login screen) gone above 70%..
And also im not found any "failed" item in Verbose mode..
i dont know how to use Safemode to solve the problem..
plz help me..
Living for Learning & Learning for Living
Sathish is offline
Old 29-06-2008, 01:48 PM   #2 (permalink)
Pat
Member of Apple Family
Pat's Avatar
Default Re: Help me...On Linux Booting..
What is the last line in verbose mode after which your system hangs ?
Pat is offline
Old 29-06-2008, 03:36 PM   #3 (permalink)
Sathish's Avatar
Post Re: Help me...On Linux Booting..
Last line is:
ALSA Driver (Version 1.0.16) is already running. Doing alsactl to [ok] mixer settings;
My Config
AMD Athlon 64 X2 4200
A8N-VM-CSM (onboard SoundMax HD audio)
2GB RAM, 7600 GT, 19' TFT
Sathish is offline
Old 29-06-2008, 04:16 PM   #4 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
From this I assume you were running the system fine once installed.
When you boot up doesn't the Menu which shows you to boot into Mandriva , Windows etc have an option for booting into safe mode or Fallback mode?
A google about this board actually shows alot of folks ranting about it for some reason. Maybe it has something to do with the display driver I guess. Do you at least get a CLI? I forgot the shortcut but isnt there a shortcut which takes you to CLI? Like ctrl + Alt +1 or something. You might want to confirm with someone who is experienced in Mandriva also.
FilledVoid is offline
Old 29-06-2008, 04:49 PM   #5 (permalink)
Sathish's Avatar
Wink Re: Help me...On Linux Booting..
thankx for replies...
im using Asus motherboard from 3 years..i have installed most type of linux distro (Fedora, Mint, Open Suse, Ubuntu and lastly Mandriva) in no. of times.. i never faced like any compatibility and stability issues like this ....
i think. the problem may be at choosing repositaries...
now i simply reinstalled mandriva 2008 and it works fine with all updates..
Sathish is offline
Old 29-06-2008, 04:58 PM   #6 (permalink)
Married!
Rahim's Avatar
Gave up so easily...
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 30-06-2008, 08:47 AM   #7 (permalink)
Dark Star's Avatar
Try using
apic nolapic apci=off
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 30-06-2008, 09:47 AM   #8 (permalink)
Sathish's Avatar
Thumbs up Re: Help me...On Linux Booting..
Hi Darkstar,,
i already stated that i have reinstalled mandriva 2008 and it took just only 30 minutes...
i think, this is only the easiest method to solve unknown problems in Linux (like for me as linux minnows)
anyhow much more thanks for your interesting....
Sathish is offline
Old 30-06-2008, 10:06 PM   #9 (permalink)
Dark Star's Avatar
Listen reinstalling a OS won't help you learning it.. try to fix the problem.. That will help you learn the problem and you will slowly gain experience like parka
Old 30-06-2008, 10:12 PM   #10 (permalink)
hullap's Avatar
*ahem* its prakash
hullap is offline
Booting into linux grmrpr Open Source 3 23-02-2007 09:07 PM
Linux booting problem vinay_001 Software Q&A 2 18-06-2006 09:15 PM
Linux Booting Problem vineetrocks2005 Open Source 2 20-05-2006 07:54 PM
Linux booting mohnishghodekar Open Source 5 27-12-2005 12:28 PM
Booting linux with NTOS loader amol_dan Open Source 1 20-05-2005 04:57 PM
- by soumya
