Old 23-06-2008, 06:56 AM   #1 (permalink)
Mad and Furious
redhat's Avatar
Default Resize Partition without affecting it??
While installing Ubuntu on my machine... i made 3 linux partitions... 1 had mount point "/", the other was swap, and for the third, i didnt know, so i kept mount point as "/home".
now, how do i access this partition??? i cant find it...
PS. If this seems silly, pls forgive but im a n00b when it comes to linux...
My new Tech Blog : http://technewspaper.blogspot.com/
redhat is offline
Old 23-06-2008, 07:24 AM   #2 (permalink)
Default Re: Resize Partition without affecting it??
Use GParted
ThinkFree is offline
Old 23-06-2008, 07:28 AM   #3 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
/home is your home folder
Apple iPad 2 16GB WiFi
MetalheadGautham is online now
Old 23-06-2008, 08:01 AM   #4 (permalink)
Married!
Rahim's Avatar
The 3rd partition is there but mounted at "/home", without knowing you have made a very good choice of making separate partition and mounting it on /home!!!
Just do sudo fdisk -l and will see the partitions.
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 23-06-2008, 09:07 AM   #5 (permalink)
Dark Star's Avatar
Look like in Windows you have System folders.. In Linux all system files goes under "/" .. You can view the files but you cannot access them as normal user.. "/home" is just like My Documents . Here you save your docs/pics/music/videos and all saved settings are save here. You can access it as your Home and can edit files in it !
Swap is like temp folder.. It guess which pages will soon be needed, and start loading them into RAM.You cannot access the partition as far as I know
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 23-06-2008, 04:11 PM   #6 (permalink)
Mad and Furious
redhat's Avatar
thank you for your quick replies but i have a problem now...
my root "/" partition is very huge... while i am unable to copy any file there... while the /home partition being small cannot accomodate all the documents i have...
I need to resize the partitions without affecting my data... I do not wish to re-install the OS again for this....
redhat is offline
Old 23-06-2008, 05:17 PM   #7 (permalink)
Married!
Rahim's Avatar
OK.
First Resize your / partition (shrink it) and then merge the new unallocated space with /home partition.
Its that simple.
Rahim is offline
Old 23-06-2008, 08:36 PM   #8 (permalink)
Mad and Furious
redhat's Avatar
u mean i can really shrink n merge without affecting the data??
which app for that?? n also, what size should i keep for the "/" partition??
redhat is offline
Old 23-06-2008, 09:17 PM   #9 (permalink)
Married!
Rahim's Avatar
Yes you can Use GParted Live CD for all partition needs.
If you have space then keep 7-10 GB for / and the rest for /home. It depends on your usage.
Rahim is offline
Old 24-06-2008, 06:37 PM   #10 (permalink)
Mad and Furious
redhat's Avatar
^^thanks a lot
I tried using Gparted, but I am facing a error
It is allowing to shrink my "/" partition, but not allowing me to merge the freed space onto my "/Home" partition... How do I get more disk space for /Home ??
redhat is offline
Old 24-06-2008, 08:38 PM   #11 (permalink)
Married!
Rahim's Avatar
I saw it on your other thread bcoz the empty space should be side-by-side with your /home partition to merge the two. Just follow what T159 has said, though it will be veryyyy time consuming. Go watch some movies while doing it
Rahim is offline
Old 02-09-2008, 08:59 AM   #12 (permalink)
To resize partition. I usually depend on the software for it is easy and safe for me, the reason is that i am not a specialist in computer What I use is EASEUS Partition Manager which did not damage any of my data and files during my usage. If you are intrested in it you can download a free one to have a try yourselfhttp://www.download3000.com/download...8809.html.hope it is helpful
stella is offline
Old 04-09-2008, 06:03 PM   #13 (permalink)
hullap's Avatar
and your nick is redhat
hullap is offline
Thinkpad R61:Installing Another Os without affecting the present one gary4gar QnA (read only) 2 30-04-2008 02:17 AM
Resize partition. sid_cool QnA (read only) 9 12-03-2007 01:29 PM
How to resize .gif images ? Third Eye QnA (read only) 13 17-01-2007 02:10 PM
Resize my drive rohan Hardware Q&A 2 06-06-2006 08:27 PM
- by soumya
