Old 21-06-2008, 05:36 PM   #1 (permalink)
Mad and Furious
redhat's Avatar
Default How to mount flash Disk in Linux?
I am very new to linux... this is the first time im using it..
im using a live CD to boot into Kubunto Hardy-Heron release 8.04
I need to mount my flash drive on this but dont know how to... can someone please explain??
My new Tech Blog : http://technewspaper.blogspot.com/
redhat is offline
Old 21-06-2008, 06:00 PM   #2 (permalink)
Default Re: How to mount flash Disk in Linux?
it should be detected automatically
else
1. sudo fdisk -l
2. see which one shows as ur flash disk
3. sudo mount the flash drive
Faun is offline
Old 21-06-2008, 06:09 PM   #3 (permalink)
Mad and Furious
redhat's Avatar
i entered sudo fdisk -l in terminal window
but it returned nothing... it only showed up the next line for enetering the next command.. pls help
redhat is offline
Old 21-06-2008, 06:46 PM   #4 (permalink)
18 Till I Die............
insert the pen drive.
http://www.bash.org/?258908
mehulved is offline
Old 21-06-2008, 06:53 PM   #5 (permalink)
Kcots Hserf
trublu's Avatar
^rofl.
ASUS K53SM-SX0101D | Samsung Wave 525 | Canon EOS 1000D | 18-55 mm | 50mm f1.8
Registered Linux User #471793
trublu is offline
Flash Disk Problems casanova Hardware Q&A 3 13-03-2008 05:07 PM
How to boot from USB flash disk? h_kunte Software Q&A 2 14-01-2008 12:56 AM
dont install OS on flash drive/damn small linux corrupted flash drive vish786 Open Source 2 28-07-2007 05:29 AM
How to mount pen drive in linux tehnogeek Open Source 7 08-04-2007 10:13 PM
64 bit linux does not mount. blackleopard92 Open Source 3 20-11-2006 12:17 AM
- by soumya
