Old 20-06-2008, 12:34 AM   #1 (permalink)
Married!
Rahim's Avatar
Default Help Me to Edit FSTAB File
Bought 300 GB IDE and created 3 Partitions:
/dev/sdb1 ext3
/dev/sdb2 ext3
/dev/sdb3 vfat
Here is my fstab file
# /etc/fstab: static file system information.
# -- This file has been automaticly generated by ntfs-config --
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc defaults 0 0
/dev/sda1 /media/WinXP ntfs-3g defaults,locale=en_IN 0 0
/dev/sda5 /media/Songs ntfs-3g defaults,locale=en_IN 0 0
/dev/sda6 / ext3 errors=remount-ro 0 1
/dev/sda7 /home ext3 defaults 0 2
/dev/sda8 none swap sw 0 0
/dev/scd1 /media/cdrom0 udf,iso9660 user,noauto,exec,utf8 0 0
/dev/scd0 /media/cdrom1 udf,iso9660 user,noauto,exec,utf8 0 0
/dev/fd0 /media/floppy0 auto rw,user,noauto,exec,utf8 0 0
/dev/sdb1 /media/Linux ext3 auto,user,exec,rw 0 0
/dev/sdb2 /media/Dump ext3 auto,user,exec,rw 0 0
/dev/sdb3 /media/Multi vfat auto,user,exec,rw 0 0
But whenever i try to copy to sdb1/2/3 it sayd "You DOnt Have The Permission to write to the destination".
So how can i edit the parameters to anble me to create/delete(read/write) in the 2nd Hard Disk?
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 20-06-2008, 01:20 AM   #2 (permalink)
Default Re: Help Me to Edit FSTAB File
first edit ur fstab as given below
/dev/sdb1 /media/Linux ext3 defaults 0 0
/dev/sdb2 /media/Dump ext3 defaults 0 0
then
do
sudo mount -a
do a chown to the directory where the sdb1 and sdb2 are mounted
e.g.
sudo chown -R username:username /media/Linux
sudo chown -R username:username /media/Dump
where username is your user account name, it is displayed in terminal.
for fat i dunno wats the problem, but it should be writeable
/dev/sdb3 /media/Multi vfat relatime 0 2
them
sudo mount -a
then
try to do the chown method with fat too
Faun is offline
Old 20-06-2008, 01:31 AM   #3 (permalink)
Married!
Rahim's Avatar
Here is the error for fat partition
"chown: changing ownership of `/media/Multi/': Operation not permitted"
Rahim is offline
Old 20-06-2008, 01:42 AM   #4 (permalink)
use
/dev/sdb3 /media/Multi vfat umask=000 0 0
and then
sudo mount -a
see if now u can write on fat partition
else reboot to effect changes
Faun is offline
Old 20-06-2008, 02:00 AM   #5 (permalink)
Married!
Rahim's Avatar
^That did the trick. thanks again.
Rahim is offline
Old 20-06-2008, 02:01 AM   #6 (permalink)
anytime
Faun is offline
Old 20-06-2008, 02:19 AM   #7 (permalink)
18 Till I Die............
Why not let the VFS do it's stuff? Why live with old age tech? What you need in fstab is just your / and swap. All else can be handled by auto mounters.
http://www.bash.org/?258908
mehulved is offline
Old 20-06-2008, 09:40 AM   #8 (permalink)
Married!
Rahim's Avatar
Now everything has been setup properly thanks to T159.
The 2 ext3 partitions in 2nd drive (sdb1 & sdb2), are both named as 83 GB Media & 21 GB Media respectively on the Desktop. I want to give a label to both like "Songs" & "Videos" like it has been given for ntfs partitions or my vfat partitons(sdb3) as "Multi"(I named it through XP).
How can i do it?
Remember i have no problem with the mount points and permissions.
Rahim is offline
How to easily edit a .vob file ayushman9 Software Q&A 3 02-12-2007 09:39 AM
how to edit a PDF file yrakesh78 Software Q&A 3 24-07-2007 02:28 PM
Edit swf file possible Techmastro QnA (read only) 6 18-12-2006 01:33 AM
How To Edit A CHM File??? go4saket QnA (read only) 1 27-09-2006 11:06 PM
Help me to create and edit (.icon) file jitu_mania QnA (read only) 5 09-10-2005 07:51 AM
- by soumya
