17-06-2008, 05:51 PM
A human, I use Ubuntu
DSL connection problem in Ubuntu
Recently I installed the latest version of Ubuntu. I used pppoeconf to configure BSNL's DSL broadband connection. Things were working fine till yesterday. Then suddenly the net connection started getting disconnected automatically every 5 minutes or so. After getting disconnected, automatic re-connection happens in a short time. Since my machine is dual boot, I tried winxp and found that the connection is stable in it. But i love to work with ubuntu. What could be the possible solutions for this problem?
17-06-2008, 05:54 PM
left this forum longback
Re: DSL connection problem in Ubuntu
remove using synaptic , "network-manager" .
17-06-2008, 05:57 PM
praka123, what should I remove ?
17-06-2008, 05:58 PM
"network-manager" and related dependencies
17-06-2008, 06:11 PM
huh, so is this 'network-manager' not of much use later? or is it possible to correct this by changing some configuration settings?
Does tinkering with something called lcp solve this; i saw a reference to this among the output of 'plog' in terminal after the connection was terminated?
Reason: Automerged Doublepost
17-06-2008, 07:18 PM
Hey this is interesting. My doubt, this network-manager thingy doesnt have anything to do with our connectivity? I am connected through router mode, can i safely uninstall this once and forever?
Replies appreciated as usual ...
17-06-2008, 07:26 PM
are u connected to bsnl broadband? haven't you faced the problem similar to me ?
17-06-2008, 07:37 PM
^^ Yep, am on BSNL. I have used my connection both in bridged and router mode in Ubuntu. No connectivity problems so far.
20-06-2008, 10:26 PM
The cake is a lie!!!
Try running the 'sudo pppoeconf' again, it will be alright. This used to happen with me, but not anymore.
Though this doesn't happen very often, but whenever it does, running the command helps.
"Some things Man was never meant to know. For everything else, there's Google."
22-06-2008, 08:53 PM
i m using ubuntu 8.04 now connected to bsnl broadband.....
go to .....sudo pppoeconf...
then follow the routine...
then type in terminal.... pon dsl-provider...
then net will be connected..
to disconnect...type in terminal....poff dsl-provider....
Samsung 2233sw|AMD phenom2 x2 550 BE|gigabyte ma78gm-us2h|kingston 2x2 gb ddr2|seägate 500gb 7200.12|corsair vx450|lg dvd rw|zebronics bigli|apc 650|palit 9600 gt 512mb ddr3|altec lansing vs 4121|
22-06-2008, 09:19 PM
Debian Gnu/Linux User
Hi pradeep...
Forgot Ubuntu... try Mandriva 2008...
its fantastic, reliable and stable version..
excellent hardware recong. No.need to config for DSL/ADSL connection...it configure automatically...
Living for Learning & Learning for Living
22-06-2008, 09:23 PM
well,those choosing mandriva and all -one word rpm distros and package management is somewhat difficult.however easy you say... so Debian based like Ubuntu or Sidux.
23-06-2008, 07:27 AM
The Smaller Bang
sidux != newbies
mandriva != difficult to use
urpmi = deb
Apple iPad 2 16GB WiFi
24-06-2008, 01:07 AM
Well, for some strange reason the issue got solved by itself. However, thanks pals !
24-06-2008, 01:16 AM
gotta kidding?
