Old 01-05-2005, 12:40 PM   #1 (permalink)
Default Ethernet problem
I have already asked this but no solutions my ethernet card 8139d is identified as 8139c the green led of the ethernet card blinks meaning it works fine but even after that i am not able to connect to that it gives a coulnot find error
vasanth_12345 is offline
Old 01-05-2005, 04:05 PM   #2 (permalink)
BE FREE
Default Re: Ethernet problem
what other kind of error messages do u recieve, and check again if it is configured correctly or else tryout on another pc.
azaad_shri75 is offline
Old 02-05-2005, 03:08 PM   #3 (permalink)
What kind of problem are u facing.Give us some more detail
abhinav is offline
Old 02-05-2005, 08:52 PM   #4 (permalink)
post output of the folloing command given as root
#dmesg | grep eth0
**** happens
pradeep_chauhan is offline
Old 11-08-2005, 10:40 PM   #5 (permalink)
String Phreak
mediator's Avatar
1. compatibilty problem!
2. incorrect drivers,old OS!
3. eth.. card -> fake !
4. try FC4 or suse 9.3
mediator is offline
- by soumya
