Old 14-06-2008, 10:54 AM   #1 (permalink)
Dark Star's Avatar
Default Audio Output Problem..
Hi
Well I can't say this is a particular Linux OS Issue.. But I been facing this issue with Linux.. Ok all Linux OS detect my Realteak AC97 Sound Chip and configure it work. But when I listen any kind of Audio .. There is a problem.. After few second or minutes there is no output , its not necessary that out vanishes only when I play , sometimes it vanishes just after I log On or at any time.... The Sound output vanishes.. and it sometimes come back again in few minutes/or after a long duration ? Whats exactly the problem !
I have faced this issue in different OS except Windows { I cannot confirm the current status with Windows cause I haven't used it for years } ? Can this be rectified? Do other Linux user face similar issue ?
Regards
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 14-06-2008, 11:05 AM   #2 (permalink)
Default Re: Audio Output Problem..
not me, here my rare CMedia sound card was detected for which I struggled to get some old drivers in windows.
May be u should try
sudo killall pulseaudio
Faun is offline
Old 14-06-2008, 11:11 AM   #3 (permalink)
Dark Star's Avatar
^^Even My Chip is detected .. but Output vanishes sometimes !
Old 14-06-2008, 11:11 AM   #4 (permalink)
left this forum longback
praka123's Avatar
what driver does it use? intelx0? anyways try alsaconf in your mandriva and post the o/p of lspci.
praka123 is offline
Old 14-06-2008, 11:36 AM   #5 (permalink)
Dark Star's Avatar
[root@localhost darkstar]# alsaconf
bash: alsaconf: command not found
[root@localhost darkstar]# lspci
00:00.0 Host bridge: Intel Corporation 82845G/GL[Brookdale-G]/GE/PE DRAM Controller/Host-Hub Interface (rev 03)
00:02.0 VGA compatible controller: Intel Corporation 82845G/GL[Brookdale-G]/GE Chipset Integrated Graphics Device (rev 03)
00:1d.0 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #3 (rev 02)
00:1d.7 USB Controller: Intel Corporation 82801DB/DBM (ICH4/ICH4-M) USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 82)
00:1f.0 ISA bridge: Intel Corporation 82801DB/DBL (ICH4/ICH4-L) LPC Interface Bridge (rev 02)
00:1f.1 IDE interface: Intel Corporation 82801DB (ICH4) IDE Controller (rev 02)
00:1f.3 SMBus: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) SMBus Controller (rev 02)
00:1f.5 Multimedia audio controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Audio Controller (rev 02)
01:05.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
Old 14-06-2008, 12:57 PM   #6 (permalink)
Married!
Rahim's Avatar
I too faced the same problem in all version of Ubuntu(i think we both have the same nobo/soudcard 845gvsr) and it happened in Exaile & Audacious. Now i have switched to xine-based players and all is fine.
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 14-06-2008, 01:52 PM   #7 (permalink)
Dark Star's Avatar
Huh.. I am using Amarok /Xine backend but nothing happened !
Old 14-06-2008, 02:50 PM   #8 (permalink)
praka123's Avatar
mandriva got "alsaconf" as separate package.install it from their repo(called cooker?)
praka123 is offline
Old 16-06-2008, 08:57 AM   #9 (permalink)
Dark Star's Avatar
Nopes no progress.. Tried alsaconf and disabled pulseaudio but to no avail Is my Sound CHip the defaulter ?
Bump..
An Simple Audio Output Multiplug Choto Cheeta Hardware Q&A 13 02-01-2008 07:55 PM
Problem with TV output. slash_89 Hardware Q&A 1 03-05-2007 06:55 PM
Audio Problem santoshp QnA (read only) 3 22-09-2006 01:39 PM
TV & DVI output problem god_of_frauds Hardware Q&A 3 25-12-2005 10:30 PM
Problem in DVD sound output udhaybhavan QnA (read only) 4 06-01-2005 11:07 AM
- by soumya
