Old 09-06-2008, 09:59 PM   #1 (permalink)
drsubhadip's Avatar
Question ubuntu not connecting to bsnl broadband..
i m very new to linux and also to ubuntu..
i live in kolkata ,india..
can not connect to BSNL broadband through ubuntu..
the ifconfig say s the following...
subha@subha-desktop:~$ ifconfig
eth0 Link encap:Ethernet HWaddr 00:11:11:19:d3:6e
inet addr:192.168.1.2 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::211:11ff:fe19:d36e/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:4 errors:0 dropped:0 overruns:0 frame:0
TX packets:66 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:522 (522.0 B) TX bytes:7663 (7.4 KB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:1026 errors:0 dropped:0 overruns:0 frame:0
TX packets:1026 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:51300 (50.0 KB) TX bytes:51300 (50.0 KB)
now i ve dual boot with windows xp..
the ipconfiguration fo xp is as follows....
Windows IP Configuration
Host Name . . . . . . . . . . . . : abc-e0a4fd8e35a
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : local.lan
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : local.lan
Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connection
Physical Address. . . . . . . . . : 00-11-11-19-D3-6E
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.2
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
Lease Obtained. . . . . . . . . . : Thursday, June 05, 2008 11:18:51 AM
Lease Expires . . . . . . . . . . : Thursday, June 05, 2008 11:18:51 PM
PPP adapter Dataone:
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-53-45-00-00-00
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 117.194.195.238
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 117.194.195.238
DNS Servers . . . . . . . . . . . : 218.248.255.162
218.248.255.139
NetBIOS over Tcpip. . . . . . . . : Disabled
that is what i can tellu every body..
can any body help me to connect to the broadband through ubuntu......
please..
help me..
thanks in advance..
I LOVE UBUNTU.. it is great
Samsung 2233sw|AMD phenom2 x2 550 BE|gigabyte ma78gm-us2h|kingston 2x2 gb ddr2|seägate 500gb 7200.12|corsair vx450|lg dvd rw|zebronics bigli|apc 650|palit 9600 gt 512mb ddr3|altec lansing vs 4121|
drsubhadip is offline
Old 09-06-2008, 11:06 PM   #2 (permalink)
Default Re: ubuntu not connecting to bsnl broadband..
1. Open a Terminal.
2. Type in the command sudo pppoeconf in the terminal and hit enter.
3. Provide the information required by the program.
4. Program will now ask for your username. So type in your BSNL username and click ok.
5.Now the program will ask you for the password. Type in the password in the space provided and click on OK.
6. Program will ask you for some settings. Accept the default values.
Now your BSNL Dataone Broadband connection is configured on Ubuntu Linux.
To connect to internet type the command pon dsl-provider and to disconnect type in the command poff dsl-provider.
cool_techie_tvm is offline
Old 10-06-2008, 09:39 AM   #3 (permalink)
drsubhadip's Avatar
problem solved........
thanks everybody......
Old 10-06-2008, 10:09 AM   #4 (permalink)
Married!
Rahim's Avatar
^How? The connection has been erratic for a couple of days in Kolkata.
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
How to install Bsnl Broadband on ubuntu using usb Streetfighter Software Q&A 9 16-12-2008 10:27 AM
problem of connecting bsnl broadband by mandriva linux spring 2008 drsubhadip Software Q&A 13 16-09-2008 11:15 AM
Connecting to Internet by BSNL GPRS on W810i abhijeet_ghosh Mobiles and Tablets 3 27-09-2007 03:45 PM
Broadband Connecting error... Manshahia Broadband and DTH 2 18-03-2007 09:34 PM
connecting broadband gau_pppu Software Q&A 2 15-02-2007 10:57 AM
- by soumya
