Old 01-06-2008, 04:18 PM   #1 (permalink)
blademast3r's Avatar
Thumbs down Ubuntu resolution problem
Hey guys ive installed ubuntu on my old system... the thing is that it stats in 1024X768 resolution nd my monitor does nt support it... but i think theres a way to change the startup resolution in recovery text mode...cud sm1 pls gimme the command??
blademast3r is offline
Old 01-06-2008, 04:24 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: Ubuntu resolution problem
sudo dpkg-reconfigure xserver-xorg
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 01-06-2008, 06:04 PM   #3 (permalink)
left this forum longback
praka123's Avatar
edit /etc/X11/xorg.conf.
you can press ALT+F2 to get run.inside type:
gksudo gedit /etc/X11/xorg.conf
now,browse to section "Screen" in xorg.conf:
add the lines in bold to the places.remember:make sure you entered these bold lines just above EndSection in section "Screen" .save and restart/X .
 SubSection     "Display"
       Viewport     0 0
        Depth       24
        Modes      "1024x768" "800x600"
    EndSubSection
EndSection
good luck
praka123 is offline
Old 02-06-2008, 08:51 AM   #4 (permalink)
OSS Enthusiast!
nitish_mythology's Avatar
I had 1024*768 resolution on Ubuntu 7 but cant get it on Hardy..
Even edited the Xorg.conf file wth the help of fellow Digit IRC members, but It didnt work out!
Anyways I have formatted Ubuntu and switching to DreamLinux. So cnt work over it anymore....
Do you know, Shinigamis only eat apples???
nitish_mythology is offline
Old 02-06-2008, 01:30 PM   #5 (permalink)
I am currently using Ubuntu 8, I have nVidia 7600GS card and 17" Samsung 793s monitor... I am easily getting 1024x768 resolution with freq upto 85 Hz in XP, but in Ubuntu, it is running with Freq 50 Hz... If I try to increase it any further, the screen becomes blurry... Any help? Do I need to download any special drivers?
Arun
sakumar79 is offline
Old 02-06-2008, 07:36 PM   #6 (permalink)
praka123's Avatar
well,the native screen resolution tool reports wrong frequency with proprietary nvidia driver.you invoke "nvidia-settings" to see the correct resolution and other details.
praka123 is offline
Old 02-06-2008, 07:54 PM   #7 (permalink)
^^ So, should I run nvidia-settings through terminal? Do I need to run through sudo?
Arun
Old 02-06-2008, 07:57 PM   #8 (permalink)
yep
Faun is offline
Old 02-06-2008, 08:09 PM   #9 (permalink)
Pat
Member of Apple Family
Pat's Avatar
Arun
No need to run it via sudo! Run it directly..Also if it complains that the package/command does not exist, fire up Synaptic, search for nvidia-settings, install it and then run it again
Pat is offline
Old 03-06-2008, 07:32 AM   #10 (permalink)
^^^ Thanks guys... I installed and ran nvidia-settings and resolution is now coming properly
Arun
Ubuntu resolution mavihs Open Source 6 15-12-2007 10:37 AM
boot screen resolution prob in ubuntu 64 abhinandh Open Source 1 14-12-2007 03:06 PM
Help me Fix Ubuntu Resolution robin.rawal Open Source 4 08-06-2007 09:12 PM
Ubuntu vs Windows Screen Resolution adit_sen Open Source 6 31-10-2006 03:46 AM
Win XP resolution problem imported_dheeraj_kumar Software Q&A 1 15-07-2005 07:56 PM
- by soumya
