LinkBack (2) Thread Tools Display Modes
Old 31-05-2008, 09:30 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
TheSaint
NucleusKore's Avatar
Default OpenSuSE 10.3 Packages+Dependencies+System Upgrade May 30th 2008
Hi everyone
This is my last post of the kind for OpenSuSE 10.3. The next is going to be from OpenSuSE 11.0
I have included the usual multimedia packages for easy installation:
  • kchmviewer
  • mplayer
  • audacious
  • k3b, k3b-codecs
  • sox
  • devede
  • audacity
  • avidemux
  • ffmpeg
  • transcode
  • ntfs-config
  • vlc
  • libdvdcss
  • w32codecs
  • gimp24
Besides these I have included all the files required to upgrade the default KDE/GNOME install till date. This makes the download quite huge, one GB to be exact. See attachment at the end of this post for the complete list (list.txt). Those who do not wish to perform this massive upgrade my refer my earlier posts.
Files to download (total eleven files):
http://rapidshare.com/files/118823518/01.zip md5sum 0de570976a79e6f48161d416f35f63f0
http://rapidshare.com/files/118837511/02.zip md5sum e25247f2b3ad22bf68671892eaf45d03
http://rapidshare.com/files/118846505/03.zip md5sum 3aef2a89da2b0a7cebea95b2da7d696a
http://rapidshare.com/files/118855053/04.zip md5sum aaab8b447e57e7dc86537cfc1b335d88
http://rapidshare.com/files/118864868/05.zip md5sum d283013a8980f6b6f6f799fb37e467e3
http://rapidshare.com/files/118874131/06.zip md5sum 62ea25a9d7d1f7b747b5756f29d30caf
http://rapidshare.com/files/118883904/07.zip md5sum 299622fdaacf466fb56b64902e4d408f
http://rapidshare.com/files/118892820/08.zip md5sum d003337fd247d4048aa2d77ce53672f8
http://rapidshare.com/files/118901159/09.zip md5sum d9d407178d8061743abcb5d2fd0a3924
http://rapidshare.com/files/118909630/10.zip md5sum 8ec7ab8f59426c3a06b9ce29c3d78211
http://rapidshare.com/files/119687484/11.zip md5sum 6b204c9e3b3e828f4357a15a6388b736
Create a folder called updates in your home directory and extract all the files to it. They should not be in subfolders but in the root of the updates folder itself.
This time we are going to use Zypper
Zypper is installed by default with your OpenSuSE KDE/GNOME installation. If not you can install it through YaST->Software Management form the OpenSuSE 10.3 DVD.
Steps: (all commands are italicised, they are to be typed normally into a terminal)
  1. Press Alt and F2, a run dialog box will open
  2. Type konsole if you are a KDE user or gnome-terminal if you are a GNOME user and press ENTER
  3. Now type su and press ENTER
  4. Key in your root password and press ENTER
  5. At the # prompt type zypper ar /home/loginname/updates updates where you replace loginname with your actual login name; for example, mine will read as zypper ar /home/neville/updates updates
  6. The repository will get added.
  7. Then type zypper install kchmviewer mplayer audacious k3b k3b-codecs sox devede audacity avidemux ffmpeg transcode ntfs-config vlc libdvdcss w32codecs gimp24 and press ENTER
  8. Type y to confirm, the install of all these will take place
  9. After this you will get back an empty prompt #
  10. Now type zypper update and press ENTER, and type y to confirm when prompted to do so and press ENTER
  11. Your system will now be updated.
All the best!!!!!!
References:
http://en.opensuse.org/Zypper
http://en.opensuse.org/Zypper/Usage
Sources:
ftp://mirrorservice.org/sites/ftp.opensus.../10.3/repo/oss/
ftp://mirrorservice.org/sites/ftp.opensus...3/repo/non-oss/
http://packman.unixheads.com/suse/10.3/
http://download.videolan.org/pub/vlc/SuSE/10.3/
http://ftp5.gwdg.de/pub/opensuse/repositor.../openSUSE_10.3/
ftp://mirrorservice.org/sites/ftp.opensus...se/update/10.3/
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 31-05-2008, 11:15 PM   #2 (permalink)
TheSaint
Default Re: OpenSuSE 10.3 Packages+Dependencies+System Upgrade May 30th 2008
Let me tell you how I pull this off
When I started in December I used to do this using YaST->Software Management.
Procedure:
1. Open YaST
2. Open Software Repositories and add the required repos (see end of above post for sources I have used).
3. Open Software Management. Let's try an example. I want to install arccad. So I search for arccad and mark it for install. Now when I click continue I get the following message form YaST telling me dependencies have to be resolved, three in this case
4. So I press the Print Screen button on my keyboard to take a screenshot, save it, and click cancel in this dependency resolution window.
5. Now in the search box, search for the packages listed in the dependency window, this is where your screenshot becomes handy. You will see that YaST has already marked the packages; highlight them by clicking on them and click on the versions tab below as shown in these two images
6. Now I can see the source of the dependency. With Kwrite open I note these down one by one, and then download them.
7. I then create a folder in my Home directory with all these dependencies and the rpm of the program I want to install.
8. Add this to YaST-> Software Sources as a rpm dir repository and disable all other repositories, except the OpenSuSE DVD.
9. If I have got all the dependencies correctly it should resolve and install without a hitch. If not go back to YaST and try to see what went wrong
As you can see the whole process is quite cumbersome.
Now for this thread of one GB software install, I followed a different method. This is far simpler than the above.
Procedure:
1. Open YaST and install smart-gui
2. After this close YaST, Open a konsole and type su and become root
3. Type smart config --set remove-packages=false
4. Type smart --gui, this will open the smart package manager
5. Click on edit->channels
and add the repositories as follows
Type YaST
ftp://mirrorservice.org/sites/ftp.op...10.3/repo/oss/
ftp://mirrorservice.org/sites/ftp.op.../repo/non-oss/
Type rpm-metadata
ftp://mirrorservice.org/sites/ftp.op...e/update/10.3/
http://ftp5.gwdg.de/pub/opensuse/rep...openSUSE_10.3/
http://download.opensuse.org/reposit...openSUSE_10.3/
Click Update channels
6. Click search and mark various software for installation, dependencies will be automatically resolved. Then click on edit->upgrade all
This will upgrade the system.
Go through the entire package list in the popup that comes and search for packages with i686 (if you have an i686 architecture like me). You will have to make a note of those and download the corresponding i586 packages if you want to make redistributable updates like I do that will work well on both i586 and i686.
Click apply (the cogwheel icon) update.
7. After the update open Konqueror in superuser mode and go to /var/lib/smart/packages to see all the packages with dependencies, copy them to a folder in your home directory and if you want, change the ownership on the folder in your home directory and its contents by right clicking on it and changing the ownership in the permissions tab.
You might be wondering why have I not used smart in the above post to update the system; I ran into a lot of trouble. Smart looks for the gpg keys and gets pissed off on not finding them. I did not find a --no-gpg option in smart like zypper has. Besides a smart upgrade command was working but not smart install packagename; this is why I used zypper.
Anyway you have to copy all those packages to a /var/lib/smart/packages in a GNOME install, add all the repos as above and start the update. Only the addiitonal packages will be downloaded which is not much.
Old 05-06-2008, 03:09 PM   #3 (permalink)
drsethi's Avatar
I never found update so difficult on Suse 10.3. It has always been very easy through yast>software management. I have all above plus many other programs on my system.While total size may be 1 GB, download size is much smaller.
drsethi is offline
Old 05-06-2008, 07:26 PM   #4 (permalink)
TheSaint
It is not meant for those who have broadband connections
Old 07-06-2008, 04:06 PM   #5 (permalink)
Just curious. Why upgrade to Opensuse 11?
Please do not PM me for details about the product. Ask the questions in the forum itself.
Shipping outside Kerala is a hassle.
Ref : http://thinkdigit.com/forum/showpost.php?p=820996&postcount=53
htnakirs is offline
Old 07-06-2008, 06:28 PM   #6 (permalink)
TheSaint
I would simply because it looks promising from the reviews I've read.
Old 07-06-2008, 10:14 PM   #7 (permalink)
drsethi's Avatar
Please read
http://news.opensuse.org/category/sneak-peeks/
http://news.opensuse.org/2008/06/06/...can-mac-vicar/
http://news.opensuse.org/2008/06/05/...stephan-kulow/
Better installer, fast upgrades and many other features are available, but here I am satisfied with 10.3 and will wait for reviews after final release.
drsethi is offline
Old 26-06-2008, 09:25 PM   #8 (permalink)
drsethi's Avatar
Dear NucleusKore I want to install opensuse 11.0 to a computer not having internet connection. I have opensuse 11.0 live cd kde with me. Please tell me package to install multimedia files to it.
drsethi is offline
Old 26-06-2008, 10:55 PM   #9 (permalink)
TheSaint
Dear Dr Sethi, I have a thread for the DVD install of OpenSuSE 11.0 here
OpenSuSE 11.0 & 11.1 Packages+Dependencies June 2008
You can try that thread but I think you will have problems, there are quite a few packages on the DVD that are required as dependencies.
I have a suggestion. Why don't you do a network install on that PC if it has a LAN card, from say another PC or a laptop which will have an FTP server that contains the install DVD files? You can boot from the live cd and press F4 to select the source and install from the server. The server can be running on windows also, like Cerberus FTP server. I think you can even install from an external hard disk or pen drive that contains the DVD install files
LinkBack to this Thread: http://www.thinkdigit.com/forum/open-source/89308-opensuse-10-3-packages-dependencies-system-upgrade-may-30th-2008-a.html
OpenSuSE - Selected Packages and Dependencies (i586 & i686) This thread Refback 10-03-2011 03:08 AM
OpenSuSE - Selected Packages and Dependencies (i586 & i686) This thread Refback 07-07-2010 09:39 PM
Packages+Dependencies for Ubuntu (i386) NucleusKore Open Source 64 27-03-2010 06:39 AM
Packages+Dependencies for OpenSuSE 10.3 x86_64 NucleusKore Open Source 9 11-05-2008 07:40 PM
Anyone in Kolkata having openSUSE 10.3 or Mandriva 2008 DVD? digiz Open Source 19 01-11-2007 12:36 PM
Difference between Vista RTM N Jan 30th Release? lionelxp Software Q&A 4 08-02-2007 10:12 PM
AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!! karthik316_1999 Internet & WWW 11 18-07-2006 08:10 PM
- by kool
