| Forum |
#1 (permalink) |
I recently installed Ubuntu 8.04 dual boot with Mandriva 2008.1 .. Now Ubuntu has some problem with my system so I formatted the HDD partition of the same using Mandriva inbuilt Disk Manager in Mandriva Control Center.. After I formattedi mounted it at /media/hd1 .. I restated so that everything work fine.. Now it detects only one of the NTFS partition and Filesystem, when I open Mandriva Drive Manager it says the following error.. ![]() Now I has some valuable data . how can I recover that ? Any help would be appreciated ! fdisk -l Code:
[root@localhost shashwat]# fdisk -l Warning: ignoring extra data in partition table 5 Warning: ignoring extra data in partition table 5 Disk /dev/hda: 80.0 GB, 80026361856 bytes 255 heads, 63 sectors/track, 9729 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk identifier: 0x0dd6c6bd Device Boot Start End Blocks Id System /dev/hda1 * 1 3187 25599546 7 HPFS/NTFS /dev/hda2 3188 8287 40965687 f W95 Ext'd (LBA) /dev/hda3 8288 9607 10602900 83 Linux /dev/hda4 9608 9729 979965 82 Linux swap / Solaris /dev/hda5 ? 3597 122978 958924038+ 70 DiskSecure Multi-Boot Code:
# Entry for /dev/hda3 : UUID=3235544d-f8bf-459d-966b-de3e541f3d12 / ext3 defaults 1 1 # Entry for /dev/hda1 : UUID=CCE44E48E44E354C /media/hd ntfs-3g defaults 0 0 # Entry for /dev/hda7 : UUID=0873F1E02F80CB85 /media/hd1 ntfs-3g defaults 0 0 # Entry for /dev/hda5 : UUID=15BEB5322F467B42 /media/hd2 ntfs-3g defaults 0 0 # Entry for /dev/hda6 : UUID=0BCF489D1C56ABAA /media/hd3 ntfs-3g defaults 0 0 none /proc proc defaults 0 0 # Entry for /dev/hda4 : UUID=8bd4d2de-165a-46d0-a3da-85e9db62a11c swap swap defaults 0 0 Somebody help me .. Cause if I loose the data my sis will kill me
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/ Last edited by Dark Star; 25-05-2008 at 04:47 PM. Reason: Automerged Doublepost |
#2 (permalink) |
left this forum longback
well,why not fix the partition table first?
remember,after fixing partn table,you may not be able to boot into Linux.you have to put "fdisk -l" o/p here: So,do this: boot a livecd,open a terminal as root: run : Code:
fdisk /dev/hda now,u seems to have made a raid0 partition?there is no need for raid unless you got identical harddisks read this: http://ubuntuforums.org/showthread.php?t=706335
left this forum long back.Admin Can Delete this Account and posts Permanantly.Thank You Get GNU/Linux - http://getgnulinux.org |
#3 (permalink) |
[shashwat@localhost ~]$ su root Password: [root@localhost shashwat]# fdisk /dev/hda The number of cylinders for this disk is set to 9729. There is nothing wrong with that, but this is larger than 1024, and could in certain setups cause problems with: 1) software that runs at boot time (e.g., old versions of LILO) 2) booting and partitioning software from other OSs (e.g., DOS FDISK, OS/2 FDISK) Warning: ignoring extra data in partition table 5 Warning: ignoring extra data in partition table 5 Command (m for help): x Expert command (m for help): f Nothing to do. Ordering is correct already. Expert command (m for help): partprobe Disk /dev/hda: 255 heads, 63 sectors, 9729 cylinders Nr AF Hd Sec Cyl Hd Sec Cyl Start Size ID 1 80 1 1 0 254 63 1023 63 51199092 07 2 00 254 63 1023 254 63 1023 51199281 81931374 0f 3 00 254 63 1023 254 63 1023 133130655 21205800 83 4 00 254 63 1023 254 63 1023 154336455 1959930 82 5 20 99 47 365 114 37 371 6579571 1917848077 70 Expert command (m for help):
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/ |
#4 (permalink) |
well,nothing much.you have to mount the raid partition and see.I dont know much about raid man!.follow the link I gave.
#5 (permalink) |
I don't have RAID only 1 HDD> Also that outputwas from Mandriva, boot into Ubuntu Live and when I tried the command I get this error
ubuntu@ubuntu:~$ sudo fdisk /dev/hda Unable to open /dev/hda ubuntu@ubuntu:~$
#6 (permalink) |
in search of myself
Use
sudo fdisk /dev/sda
:::::::::::::::::::: Unban Praka123 :::::::::::::::::::: Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife "Ek Se Mera Kya Hoga" |
#7 (permalink) |
You have a pretty messed up partition table there, hda3 and hda4 looks like primary partitions to me, in that case the extended partition (hda2) should be the last partition. Also hda5 is overlapping with hda2.
#9 (permalink) |
well shashwat,you accidentally made a software raid-0 like partition then
partition 70 means " 70 DiskSecure Multi-Boot " I will recommend you,mount this raid(ntfs?) and backup your data.format it to a regular ext3 partition. always make partitions manually or using gparted,then show the distro the path to install. follow this as earlier told: http://ubuntuforums.org/archive/index.php/t-706335.html no other solution I can think of
#10 (permalink) |
Here is the output with sda in Ubuntu Live Cd
ubuntu@ubuntu:~$ sudo fdisk /dev/sda The number of cylinders for this disk is set to 9729. There is nothing wrong with that, but this is larger than 1024, and could in certain setups cause problems with: 1) software that runs at boot time (e.g., old versions of LILO) 2) booting and partitioning software from other OSs (e.g., DOS FDISK, OS/2 FDISK) Warning: ignoring extra data in partition table 5 Warning: ignoring extra data in partition table 5 Command (m for help): x Expert command (m for help): f Nothing to do. Ordering is correct already. Expert command (m for help): quit ubuntu@ubuntu:~$ partprobe Warning: Unable to open /dev/fd0 read-write (Read-only file system). /dev/fd0 has been opened read-only. Warning: Unable to open /dev/scd0 read-write (Read-only file system). /dev/scd0 has been opened read-only. ubuntu@ubuntu:~$ Isn't there software for backup ! I don't wanna lose the photo and docs . Other data doesn't matter to me "|
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/ Last edited by Dark Star; 25-05-2008 at 08:16 PM. Reason: Automerged Doublepost |
#11 (permalink) |
wait,shashwat:
do you have winblows vista installed on 80GB partition?
#12 (permalink) |
NO I don't have windows
[shashwat@localhost ~]$ su root Password: [root@localhost shashwat]# mount -t ntfs-3g /dev/mapper/isw_cdbechhbgi_Volume0 /media/raid0 ntfs-3g: Failed to access volume '/dev/mapper/isw_cdbechhbgi_Volume0': No such file or directory Please type '/sbin/mount.ntfs-3g --help' for more information. [root@localhost shashwat]# dmraid -r No RAID disks [root@localhost shashwat]#
#13 (permalink) | |
again what is the output of "fdisk -l" ?
do u have 2 harddisks? also,install this utility called "testdisk" .it will come handy. dont delete the partition in despair and panic. I am completely clueless reg something with winblows still,look what I found: Quote:
So,it will be some small file crapped by winblows? or freedos /
left this forum long back.Admin Can Delete this Account and posts Permanantly.Thank You Get GNU/Linux - http://getgnulinux.org Last edited by praka123; 25-05-2008 at 09:09 PM. Reason: Automerged Doublepost |
#14 (permalink) |
The Smaller Bang
not only the partitions, your keyboard has also corrupted.
look at the topic title.
http://TheSmallerBang.wordpress.com eMachines E725 - T4400 2.2GHz, 1GB, 160GB Nokia 5130XM * T-Sonic 610 2GB Nokia 2323C * Samsung Galaxy Y Apple iPad 2 16GB WiFi |
#15 (permalink) |
I have posted the output of fdisk -l Check 1'st post , posting it again
[root@localhost shashwat]# fdisk -l Warning: ignoring extra data in partition table 5 Warning: ignoring extra data in partition table 5 Disk /dev/hda: 80.0 GB, 80026361856 bytes 255 heads, 63 sectors/track, 9729 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk identifier: 0x0dd6c6bd Device Boot Start End Blocks Id System /dev/hda1 * 1 3187 25599546 7 HPFS/NTFS /dev/hda2 3188 8287 40965687 f W95 Ext'd (LBA) /dev/hda3 8288 9607 10602900 83 Linux /dev/hda4 9608 9729 979965 82 Linux swap / Solaris /dev/hda5 ? 3597 122978 958924038+ 70 DiskSecure Multi-Boot [root@localhost shashwat]#
#16 (permalink) |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Currupted Nokia Pc suite | hullap | Software Q&A | 2 | 07-02-2007 08:03 PM |
| help needed - creating recovery discs/partitions | premrajeev | QnA (read only) | 2 | 28-06-2005 02:04 PM |
| XP profile currupted :( help ! | vijaythefool | Software Q&A | 2 | 20-11-2004 07:30 PM |
| Help Badely Needed.......My Xp is currupted... | saROMan | Software Q&A | 16 | 03-10-2004 03:03 PM |
