Old 22-05-2008, 02:46 PM   #1 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Default Fedora 9 / bootpart issue
i installed fedora 9 on my system , chose the boot loader to install into first sector of boot partition (/) ,so i can use bootpart to use it..
now the problem is i cant configure how to set it up..
my drives are--
/ 13.54gb
and /home 9.77gb
swap is 2gb
i tried various settings but it didnt work..
here's bootpart screenie--
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 22-05-2008, 05:38 PM   #2 (permalink)
The Unknown's Avatar
Default Re: Fedora 9 / bootpart issue
aah dude, why ppl mess with the boot loader... the installer doesn't disturb windows. insert your f9 dvd, choose rescue mode, then type 'linux rescue'
it will leave you to a shell prompt.....
then type 'chroot /mnt/sysimage'
then type 'grub-install /dev/sda'
this should install grub to the first partition on the MBR of the first hdd
KDE on ArchLinux
The Unknown is offline
Old 22-05-2008, 05:56 PM   #3 (permalink)
Alter Bridge=GOD
that i know but i want to keep that Vista and xp bootloader as default
Old 22-05-2008, 06:08 PM   #4 (permalink)
left this forum longback
praka123's Avatar
well,in that case,you have to ask windows guys to how to add Linux to windows boot menu.
also,there are few 3rd party boot loaders too.
the best IMO is to install grub,make vista and xp boot options.
if you prefer to boot into xp,no problem grub got that option too!without showing grub menu,grub can boot into xp/vista .
For that you have to use "hiddenmenu" option with time out to be 3sec rightly.
if you want at the moment to boot into Linux,no problem,press ESC key and grub menu will appear
I think Fedora by default has "hiddenmenu" option albeit set for "fedora" to boot as default
praka123 is offline
Old 22-05-2008, 06:11 PM   #5 (permalink)
Alter Bridge=GOD
ok .. but what if my windows xp gets corrupt (no i m not talking abt that due to linux)? will my linux go kaput too?
Old 22-05-2008, 06:19 PM   #6 (permalink)
Juke Box Hero
I did a few searches and found these
http://my.opera.com/lamdaiphong/blog...-to-boot-linux
http://port25.technet.com/archive/20...M-Support.aspx
For your other question, if your Windows goes kaput, no worries, just install Windows normally and the MBR will get overwritten with Windows. Linux is still there except its entry has been cleared from the MBR by the Windows installation. All you need to do is as said by The_Unknown above, to restore GRUB on the MBR.
Hitboxx is offline
Old 22-05-2008, 06:21 PM   #7 (permalink)
praka123's Avatar
well,Linux dont cause ur winblows to corruput ,unless may be using ntfs-3g?? driver for writing to ntfs partitions
the best option imo,is to use grub with hiddenmenu,it is almost the same as if booting directly into xp.
BTW why vista?
praka123 is offline
Old 22-05-2008, 06:29 PM   #8 (permalink)
Alter Bridge=GOD
thats what i said..i was talking about me messing with winblows xp and having to reinstall it again
Old 22-05-2008, 06:32 PM   #9 (permalink)
you can have grub loading winblows by default
KDE on ArchLinux
Old 22-05-2008, 06:33 PM   #10 (permalink)
praka123's Avatar
well,the options are given by me and hitboxx.
getting corrupted by ntfs-3g and fuse is got little chance.you may not worry.anyways after 4-5 months windows got this phenomenon called "windows rot" ,so anyways reinstalling winblows is there!
http://www.theopensourcery.com/wordp1/index.php?p=400
praka123 is offline
Fedora goes next gen! Fedora 8 Test 1 Released Dark Star Open Source 24 10-08-2007 11:39 AM
No more "Fedora Core" but Fedora praka123 Open Source 8 15-01-2007 10:57 AM
RAM Issue.. dreams Hardware Q&A 13 26-01-2006 08:51 AM
RAM Issue speedyguy Hardware Q&A 13 20-01-2006 06:11 PM
Issue installing PCQLinux 2005 and Fedora Core3 FilledVoid Open Source 1 23-05-2005 10:09 AM
- by soumya
