Old 16-05-2008, 12:00 PM   #1 (permalink)
AFK
thewisecrab's Avatar
Question Need Help in Virtual Box (Warning:I'm a Linux noob)
Hi Guys
I was not too keen on making the switch from Windows to Linux
Still I want to check it out
I have decided to use Virtual Box
I have the Digit DVD with Mandriva One 2008.1
Can you'll tell me how to install it on a Virtual Drive?
I googled only to find Virtual Box on XP with Ubuntu
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 16-05-2008, 12:15 PM   #2 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Default Re: Need Help in Virtual Box (Warning:I'm a Linux noob)
I could give you the way I do it on ubuntu. SO you might confirm if there any differences.
but even before that isn't that DVD a Live DVD? That is , doesn't it boot off the DVD and run in Live Mode so that you can give it a try before installing?
FilledVoid is offline
Old 16-05-2008, 12:22 PM   #3 (permalink)
JGuru's Avatar
@thewisecrab, Ubuntu Linux is a Live CD/VDVD. It boots from the CD/DVD & runs all the programs
from the CD/DVD. So there's no need to panic!!! Straight away boot using the CD/DVD & find
out for yourself. No changes are made to your HD partitions.
NOTE: If you do find something that you don't understand, You can ask for help, by posting
your query here.
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
Old 18-05-2008, 09:35 AM   #4 (permalink)
OSS Enthusiast!
nitish_mythology's Avatar
Can anyone explain the concept of Virtual Box??
Why do we need such stuff whn we have Live Cds??
Do you know, Shinigamis only eat apples???
nitish_mythology is offline
Old 19-05-2008, 10:38 AM   #5 (permalink)
AFK
OK
I have created an 8 GB Virtual HDD
with 512 MB Ram ( I have 2 GB)
Mandriva Live CD "boots" up and runs fine
now i need a little guidance on installing it on the virtual drive
Old 19-05-2008, 03:45 PM   #6 (permalink)
Resistance is Futile.
coolpcguy's Avatar
Virtual Box allows you to create a "virtual machine". A Virtual Machine is for all practical purposes same as a physical("reaL") pc, but in a Virtual PC everything is emulated - from processor to HDD to network cards. I use VirtualBox to test different linux distros - a live cd just gives a sneak peak, I'd have to install it on my machine to actually test it. By using VirtualBox, I can create a virtual pc, complete with virtual hdds, and can test whatever I wont without the fear of losing any of my data on my physical machine.
Super User ♦ Moderator | chip/tech2 forum Mod | About me
Gadgets: HP Envy 14 | Google Cr-48 | D-Link DGL 4500 | Denon AH-C360 | Fiio E5 | Galaxy SII GT-I9100 | Dell U2312HM
coolpcguy is offline
Old 23-05-2008, 10:39 PM   #7 (permalink)
Beware of the innocent
ilugd's Avatar
@the wise crab Have you installed it? If the live cd boots up in the virtual machine, there should be some icon called install on the desktop. Double click on that and follow the installation. If you are stuck, just save the machine state. Ask the question here, get the answer and power up the machine again.
Life is too short. Have fun.
ilugd is offline
Old 24-05-2008, 12:05 AM   #8 (permalink)
Thinking Different
sourav123's Avatar
Originally Posted by thewisecrab View Post
Hi Guys
Just one small advice. If you are a newbie, then try using Ubuntu first. This is not only because it is easy to use, but it has the largest support base which means you can get answer to your problems very fast if you are stuck.
Also, Ubuntu 8.04 comes with Wubi installer support. Using Wubi, you can install Ubuntu from Windows just like any other software. It will also set up the dual boot for you.
There is nothing more powerful than an idea whose time has come.
sourav123 is offline
..::Linux Noob::.. hahahari Open Source 14 24-01-2008 12:59 PM
Noob Linux User Ecko Open Source 13 12-01-2008 03:23 PM
Linux on Virtual PC nvidia Open Source 6 27-10-2007 10:22 PM
common reasons why people new to Linux have installation failures-noob must read :) praka123 Open Source 17 03-03-2007 06:23 AM
linux warning message desmond_315 Open Source 2 21-08-2006 05:40 PM
- by soumya
