Old 14-05-2008, 01:23 PM   #1 (permalink)
Dark Star's Avatar
Default Ubuntu 8.04 HDD Mount Problem
Well after install I don't have any problem but after the update my partitions aren't getting mounted automatically.. Also after I click them they get Mounted but as a Disk Not as Hard Drive
Any Idea about the problem ! Just one point Ubuntu only has added 2 gr8 things Transmision and Brasero.. Loved both of em. but I thin they are not enough to make it good for 3 years.. There are lots of bugs that I seem right away .. Like CCSM installed and no other option under Visual Effects and many more
Regards
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 14-05-2008, 02:23 PM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: Ubuntu 8.04 HDD Mount Problem
try,restarting HAL
"sudo /etc/init.d/hald restart"
praka123 is offline
Old 14-05-2008, 02:34 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Did you too do a Wubi installation?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 14-05-2008, 02:51 PM   #4 (permalink)
Dark Star's Avatar
I don't have Windows so how can I do that
shashwat@shashwat-home:~$ sudo /etc/init.d/hald restart
[sudo] password for shashwat:
sudo: /etc/init.d/hald: command not found
Old 14-05-2008, 03:40 PM   #5 (permalink)
Dark Star's Avatar
Entries missging from FSTAB
# /etc/fstab: static file system information.
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
proc            /proc           proc    defaults        0       0
# /dev/sda3
UUID=23c1deaf-4020-46da-8803-03bee09a3e07 /               ext3    relatime,errors=remount-ro 0       1
# /dev/sda4
UUID=8bd4d2de-165a-46d0-a3da-85e9db62a11c none            swap    sw              0       0
/dev/scd0       /media/cdrom0   udf,iso9660 user,noauto,exec,utf8 0       0
/dev/fd0        /media/floppy0  auto    rw,user,noauto,exec,utf8 0       0
Old 14-05-2008, 04:10 PM   #6 (permalink)
http://ubuntuforums.org/showthread.php?t=359166&page=2
Faun is offline
Old 14-05-2008, 05:49 PM   #7 (permalink)
Dark Star's Avatar
^^Didn't worked ! Installing Mandriva !
Old 14-05-2008, 11:39 PM   #8 (permalink)
in search of myself
CadCrazy's Avatar
There is no entry for any partition other than your main ext3 ,swap partition in fstab. Try to enter the details manually there.
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
CadCrazy is offline
How to mount NTFS partition in Ubuntu DeSmOnD dAvId Open Source 53 24-08-2007 01:54 AM
How to mount HDD in Ubuntu?? bhushan05d251 Open Source 3 21-06-2007 12:26 AM
Ubuntu live CD cant mount HDD Tech.Masti Open Source 4 02-04-2007 11:57 PM
How to mount windows drives in Ubuntu 6.06? alanpaladka Open Source 5 03-12-2006 05:31 PM
Mount NTFS in Ubuntu nishant_nms Open Source 4 07-12-2005 02:46 PM
- by soumya
