Old 14-05-2008, 12:59 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
mak1012's Avatar
Default XAMPP not working
hi,
i just insatll xampp in my kubuntu box..
i'm able to run the http://localhost/ butwhen i put my own work in htdocs and try to access it does not show me the...result..and one moe thing i noticed that when i try to access the 'http://localhost/'
it goes to the 'http://localhost/xampp/'.
please help me to configure it.
thank you.
Every Body Says I'm Fine.
mak1012 is offline
Old 14-05-2008, 01:29 AM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: XAMPP not working
Ok, just to clear the confusion, XAMPP is WORKING!
Go to the folder \xampp\htdocs and delete or rename the index.php and index.html files.
गीक होना माँगता
victor_rambo is offline
Old 14-05-2008, 01:34 AM   #3 (permalink)
backup the file named index.php in your htdocs folder to index.php.bak (or nething) and then bring in ur new index file here, hit localhost on your browser, it should work now!!
Digitizor - How-To Guides, Tips and Tricks, Latest from the tech world and much more... visit http://digitizor.com/ now
dkd903 is offline
Old 14-05-2008, 01:47 AM   #4 (permalink)
mak1012's Avatar
the server is running but the file is not reading...from the "htdocs" folder.
No it not working....htdocs folder is in /lampp/htdocs....
there is any configuration in the xampp which i have to do.
thank you
mak1012 is offline
Old 14-05-2008, 02:06 AM   #5 (permalink)
18 Till I Die............
Put your files in htdocs/xxx then navigate to localhost/xxx
If that doesn't work, check the DocumentRoot, in your apache config file.
http://www.bash.org/?258908
mehulved is offline
Old 14-05-2008, 07:56 AM   #6 (permalink)
mak1012's Avatar
yes you are right i'm not able to navigate to localhost/xxx after putting file in htdocs/xxx.
hey mehul can you pleaase tell where exactly i can find the Documentroot. i'm not able to find it.
mak1012 is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/open-source/87770-xampp-not-working.html
Thread XAMPP not working | Digit Forum | BoardReader This thread Refback 19-06-2010 09:57 PM
internet not working on vista but working on xp kanz Software Q&A 4 15-04-2008 05:28 PM
TUTORIAL - Setting up LAMPP using XAMPP sachin_kothari Open Source 4 30-05-2007 10:12 PM
Pc not working Cool G5 Hardware Q&A 11 01-01-2007 07:03 PM
** Working/Not-Working Programs with VISTA ** PrinceHeart Software Q&A 42 01-10-2006 04:01 PM
dvd rom not working Jitendra_gamer QnA (read only) 3 07-05-2005 11:20 AM
- by soumya
