Old 12-05-2008, 03:05 AM   #1 (permalink)
Somebody stop me...
Default help : wireless connection not working in suse 10.3
Hi, I have installed suse 10.3 on my compaq laptop. but Knetworkmanager is not listing any wireless network around.. I have manu wifi connection arround me..
network card is intel pro/wireless 3945ABG
any help would be useful
swordfish is offline
Old 12-05-2008, 11:20 AM   #2 (permalink)
Console Junkie
aditya.shevade's Avatar
Default Re: help : wireless connection not working in suse 10.3
Is the card detected? If it is, then startYaST then go to network namager. Select the card from the list, configure it from there.
You have to give the encryption password and type (if any) and the internal IP address if you are using one. Then click on the panel icon of the network and enable wireless networking...
see if it helps.
--- Console Junkie
aditya.shevade is offline
Old 12-05-2008, 12:07 PM   #3 (permalink)
Somebody stop me...
Thanks for replying..
Card is detected..
I have tried to configure the card via yast but didnt help.. I didnt set internal ip but i wll try it..
main prob is knetworkmanager has tabs disabled..
Also my card is working as i can see the connection available using iwlist command..
Old 13-05-2008, 07:27 AM   #4 (permalink)
TheSaint
NucleusKore's Avatar
Doesn't look too good
http://forums.suselinuxsupport.de/in...howtopic=61424
Anyway, try, you have to enable network manager in yast when you open the card to configure (there is a checkbox to be ticked in the first screen).
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Which Wireless Internet Connection has best speeds? go4saket Internet & WWW 7 25-04-2008 10:30 PM
want to schedule my wireless connection anilmail17 QnA (read only) 1 25-10-2007 10:55 PM
wireless in suse 10.2 saurabhgoogle Open Source 5 31-01-2007 10:47 AM
Making my net connection wireless doom_marine QnA (read only) 4 13-05-2005 07:38 PM
Wireless Connection futuristically_ancient QnA (read only) 2 02-12-2004 06:12 PM
- by soumya
